Harness part number
Old Mar 3, 2017 | 08:20 AM
ac max 92's Avatar
Harness part number
Would anyone happen to know the part number for the harness that goes to knock sensor part # 22060-56S10? I can't seem to find anything anywhere?? I believe it's a single wire for this knock sensor on the rear block of the vg but correct me if I'm mistaken..
Old Mar 3, 2017 | 07:51 PM
DennisMik's Avatar
The part # is 24079-85E00 but it is a discontinued item.
I think I found it on e-bay, but I am not 100% sure as I don't have a harness to look at.
http://www.ebay.com/itm/Knock-Sensor...3D311080225134
Further down on the page in a box called ITEM SPECIFICS, it uses a nissan part # of 24079-31U01 that when looked up on a Nissan parts website, it comes back as an EGI harness.
Another link to the same item by the same seller:
http://www.ebay.com/itm/Wiring-Harne...FXSZsU&vxp=mtr
Old Mar 4, 2017 | 04:57 AM
ac max 92's Avatar
Hi Dennis, That harness is actually for the donut style knock sensor. The sensor on the vg under the rear manifold is a green sensor that has the threads built into it and is like a tube style and if I'm not mistaken appears to have a single wire going to it. It seems to a little tougher to find than the donut style one that you kindly provided the link for.
Old Mar 4, 2017 | 02:20 PM
DennisMik's Avatar
Sorry for the false alarm. The Nissan part number I gave you is for a VG engine, the part number for a VE is different, 24079-96E00.
Regardless of which number I lookup, I always get the same cable like the e-bay one. The after-market suppliers don't seem to understand that there a 2 different cables.
Here is a link from New Zealand for a connector. Is this the connector?
http://www.nzefi.com/product/nissan-...b20-rb25-ca18/
And another place - I don't know where they are.
http://www.wiringspecialties.com/connectort.html
this one is in Australia
https://pontiworld.com.au/usgmsp/pro...3cd1e0f9a9fe7a
Old Mar 13, 2017 | 10:02 AM
ac max 92's Avatar
Hi Dennis, I do have a vg. That single wire connector looks to be right. I'll have to find out for certain but to my knowledge the KS is on the block under the rear manifold and I believe the KS I have is the green tubular style rather than the donut style but I still have to check for certain. I'm not sure if the vg changed to the donut style at any point in 92 but I figured I'd try and find that single wire connector/harness incase it's the one I'll be needing. Thanks again for the links and your help and input ☺
