window problem
Old May 3, 2017 | 04:33 AM
markevans999's Avatar
window problem
1994 maxima gxe. around 120k miles
got in the car, closed the door and heard a loud clank like something broke. looked around but could see nothing wrong. started the car and pulled out of the garage. went to lower the drivers side window and the window just dropped.
when i press the window button up or down i can hear the window motor running but nothing happens.
any ideas what happened?
thanks
Old May 3, 2017 | 08:34 AM
DennisMik's Avatar
Most likely the window regulator broke. The window regulator is like an elevator that moves the glass up and down. A much less likely possibility is that the bolts that hold the glass onto the regulator loosened and fell out.
You will have to have to remove the inside trim panel from the door and look inside to see exactly what has happened.
If it is the regulator, you can buy the regulator with ($110) or without ($35) the electric motor.
Old May 3, 2017 | 08:58 AM
not doing the work myself. should i replace the motor while everything is apart.
thanks
Old May 3, 2017 | 09:10 AM
Tarzan's Avatar
likely the cable snapped on the regulator. dunno about you, but from my perspective cables are non-repairable
Old May 3, 2017 | 04:54 PM
Darkwing48's Avatar
You know, I didn't want to do my window regulator.
You should see the fear in the mechanic's face when I asked him how much to replace it.
A coworker of mine said he rather replace engines than the regulator.
Old May 4, 2017 | 06:14 AM
Tarzan's Avatar
Why? I replaced a regulator in a 3d gen Max passenger front door. Not a big deal.
Old May 4, 2017 | 10:08 PM
DennisMik's Avatar
Gotta agree with Tarzan.
Old May 5, 2017 | 08:54 AM
khakuda's Avatar
I have a 1994 with about the same miles and have been through many window regulators over the years. I had a mechanic do the first one at $200+, then I learned to do it myself and can now do it in 20 - 30 minutes tops.
Just have confidence and follow these genius instructions that an extremely cool person was nice enough to take the time to post long ago:
http://web.archive.org/web/200908310...regulator.html
Old May 11, 2017 | 11:44 AM
broken cable. thanks for your info.
Old Jun 7, 2017 | 06:54 PM
FanaticMadMax's Avatar
it not very hard to do window regulator. Don't know why some of you guys sounded like a dreadful job. despite "some disassembly required" LOL
