Aquarium door jamb
Old Aug 15, 2018 | 06:30 AM
Vg30ekid's Avatar
Aquarium door jamb
im having a problem with my 1993 se whenever it rains. My door jambs on the driver side get full of water whenever it rains and I’m not sure where the water is coming in from.
Old Aug 15, 2018 | 10:14 AM
DennisMik's Avatar
My guess is that it is from the door. Car designers cannot prevent water from getting inside the door, so there are slot-shaped drains on the bottom of the door towards the outside edge. If the drains get plugged, then the bottom of the door fills until the water level reaches an access opening and then leaks into the car.
You could open the door and look on the bottom and poke something up into the drain slots. But this just pushes the debris out of the way and it will eventually plug the openings again. The permanent solution is to pull the door panel off and clean the debris out.
Old Aug 15, 2018 | 03:06 PM
ac max 92's Avatar
^Agreed. Something has to be plugging the drain holes. Pulling the panel off and cleaning out the bottom of the door isn't a very difficult job anyway and should solve your problem.
Old Aug 16, 2018 | 04:16 AM
Prophecy99's Avatar
oem door gasket , mine does the same and its the door gasket
Old Aug 19, 2018 | 06:39 AM
Vg30ekid's Avatar
Idk if y’all can’t read or have a **** in your faces but i clearly put it’s in the door jambs not the door
Old Aug 20, 2018 | 04:36 AM
ac max 92's Avatar
Well if you want to get technical the pic you posted is of your rocker panels and the same principle would apply. If need be just drill a couple small holes for drainage. It's not rocket science and there's no need to be rude to people who are only trying to help.
Old Aug 20, 2018 | 05:40 AM
Prophecy99's Avatar
lol, gravity , you should google the word drainage , good luck gettin help w that attitude.
Old Aug 20, 2018 | 06:52 AM
ac max 92's Avatar
He had the same attitude in a thread about his stock Bose unit. Maybe a Would give the vg kid with a ve the help he's looking for ?
09Maxima_Sam
Oct 26, 2017 03:14 AM
Oldgascar
Nov 6, 2012 05:52 PM
04 maxse
Mar 27, 2002 11:17 PM
