Dash lights not working all of a sudden
Old Sep 14, 2020 | 10:28 PM
Odyssey L Peters Sr.'s Avatar
Dash lights went out but when pressing brake pedal dash lights come back on!? Any idea what’s causing this and how can I fix it! Thanks in advance
Old Sep 15, 2020 | 06:22 AM
badazzsupamax's Avatar
I do not believe that there is a switch that connects the brakes to the dash lights, but I do know that that may have something to do with surging. So if your alternator is fluctuating or not charging right, you will have those issues. Either that or an electrical problem. Swap around your relays and check your fuses. Also take your car to advance and have them check your alternator.
Old Sep 15, 2020 | 05:06 PM
Darkwing48's Avatar
Agreed. My Dash lights stopped working when my alternator went out... and another time when a short in my Tail Cluster blew a fuse.
Old Sep 17, 2020 | 05:25 AM
So did you figure out the issue?
Old Sep 18, 2020 | 12:15 PM
Darkwing48's Avatar
Yes. For me I replaced my taillight cluster which cause the fuse to blow. For you, it's another story. Does all your fuses have their correct value? And is your battery measuring 14 Volts while running?
Old Sep 21, 2020 | 05:57 AM
My volts are usually at 13.5 to 14.1
Old Sep 21, 2020 | 11:23 AM
Darkwing48's Avatar
The hard part is what is the voltage when you are braking?
Old Sep 22, 2020 | 05:45 PM
Issue fixed
It was just a fuse!!!! Think I shorted out fuse when changing headlights a couple days before this! Fuse was hot on one side and still in contact but after I replaced fuse, dash lights came back on and brake light works properly
mungrin
Nov 26, 2003 11:30 PM
cbrflyer919
Apr 7, 2003 02:07 PM
animal72
Sep 27, 2001 09:20 AM
