More VE problems
Old Oct 22, 2020 | 01:49 AM
maxima278's Avatar
More VE problems
After second set of injectors put in this thing it was running absolutely perfect. Overnight somehow it decided to break again. Very hard starting and sometimes not at all, running rough, smells of unburnt fuel. Check engine light came on, pulled codes as follows
12 Mass airflow sensor
13 coolant Temerature sensor
34 knock semsor
I'm sure all three of those things didn't go at the same time, anyone have any idea?
If it helps, I did notice in the best of times at first start up the car did not idle up, took a little bit of throttle to get it to even out where it would idle and not die. That sounds like a coolant temp sensor to me.
Old Nov 10, 2020 | 05:46 PM
James92SE's Avatar
2 VE's are better than one!
Corroded wiring leading into the CTS? Seems to have happened on every VE I've had.
jkklim
Aug 30, 2004 08:13 AM
99SEL4ME
Feb 18, 2004 06:31 AM
Spectre
Jun 3, 2003 09:43 PM
erivera788
Dec 12, 2002 08:33 PM
JeepRage
Jun 9, 2001 03:59 PM
