someoe help me
Old Feb 8, 2002 | 01:11 PM
MaximaSpeedNYC's Avatar
someoe help me
Ok i have a 90 SE Max with a 94 se engine and i just added a new Exhaust Muffler, no Y-Pipe or anythin else, and now everytime i go in my car in the morning my car must warm up for 5-10 min or if i dont do that and i go in drive my car wont move it will fill like its in neutral. why does that happen? Also when it switchin gears it takes longer, when its goin to the higher gear like 3rd or so it redlines before switchin gears then a big burst of speed comes out, why is this happenin? is it suppose to happen or is it cuz my pipes need to be bigger for my muffler? how much do Y-pipes cost? someone help me
Old Feb 8, 2002 | 01:21 PM
N34JZ's Avatar
Needs non-Maxima Friends
sounds like the tranny and not the exhaust
do you have auto or stick? Im almost positive its not the exhaust.
Old Feb 8, 2002 | 01:32 PM
Re: sounds like the tranny and not the exhaust
Its a Automatic, Could it be that i might need a tune up? could it be that i need a Y-pipe? and also how much does a y-pipe cost? i know it cant be my transmission becuz my transmission is pretty good, it has 53,000 miles on it.
Old Feb 8, 2002 | 01:33 PM
Jeff92se's Avatar
I'm needing a caw
I kinda want to know how you managed to fit an dohc Ve engine w/ direct coil on plug ignition to a maxima that orignally had a VG w/ dist type ignition.
Old Feb 8, 2002 | 01:39 PM
haha no idea how i had it done, my grandfather is a mechanic/cardealer, and he did it for me. I didnt ask any questions, he always fixes my maxima, Ive had this car since 93 and everyone asks how do i still have this car and its all because of my grandfather, my original engine blew so tahts why i got it changed
Old Feb 8, 2002 | 01:41 PM
Matt93SE's Avatar
STFU n00b!
if you know enough to do that engine swap, you should know enough to figure out that's a tranny problem and has absolutely nothing to do witht he exhaust.
FYI, exhaust on both VG and VE maximas were exactly the same. I've had both of them side by side and they're the same parts once you get past the manifolds.
Old Feb 8, 2002 | 01:42 PM
DanNY's Avatar
Ad·min·is·tra·tor
yup..tranny prob
got pics of the car?
Old Feb 8, 2002 | 01:48 PM
ChrisCheezer's Avatar
I know!!
dude i had the same problem when i first boguht my car
, it goes away if you shift in to P and then D again right? (sometimes?)
how many miles??
let it warm up before driving... when the RPMs drop to 1000 your good to go ... it will take about 5 min. do that for ever and start using in some crazy engine treatments (not Z max!!) pro long works great...., you could need a tune up.. but with good treatment is goes away .. it never happends to me anymore.... try getting a CAI as your next mod...
Old Feb 8, 2002 | 01:49 PM
Lordrandall's Avatar
Does your new engine look the same as your old engine?
I have a feeling this is just a VG -> VG swap guys.
Old Feb 8, 2002 | 02:11 PM
N34JZ's Avatar
I cant see how the VE could fit?
I thinks its VG->vg also.
Old Feb 8, 2002 | 02:26 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
why would you want to take pics of that???
Old Feb 8, 2002 | 02:29 PM
Matt93SE's Avatar
STFU n00b!
A VE would fit, that's no problem. the problem is the wiring on it. adapting that wiring harness would be a nightmare.
as for the real problem, have you checked the tranny fluid level lately? sounds like it's low.
Old Feb 9, 2002 | 05:46 PM
Yea well today i finally found the problem, when teh converted my engine to the newer one, the dip sticks changed around becuz it went from a VG engine to a VE. Ive been checkin the transmission fluid thinkin it was the oil and i overflooded the oil tank and it smoked up on me today so i took it to my grandfather and i had absolutely NO transmission fluid in it, so that was teh problem, now its ok. I almost threw away a Fairly new engine down the drain. for the guy who asked it has 53,893 miles to be exact. and for everyone that said it must be VG->VG it isnt its indeed VG->VE.
Old Feb 10, 2002 | 11:50 AM
medic's Avatar
I had exactly the same problem about two months ago, it's not a tranny issue, it a $7 plastic gromit that busted. You need to get from Nissan. If you take it to a mechanic they can install it for about $30.
I cna't tell you exacly where it is, I thought it was a tranny issue too on my car, but the guys at AAMCO had seen it before (they said it's common on old maximas - i've got a 93). They fixed it and had me out of there in an hour. It's been working great ever since.
Old Feb 10, 2002 | 03:06 PM
Pervis Anathema's Avatar
I guess we would need a picture that had both his engine bay and VIN in the same shot. Only way to prove that the car is a pre '92 SE with a VE in it...
Maxima90SE
Jan 3, 2002 05:32 PM
Trippy_D
Nov 9, 2000 04:51 AM
