Door code????
Old Apr 8, 2023 | 12:39 PM
abunai's Avatar
Door code????
Is there a way to find out what the code is for the door???
I never used it, but I'm getting old, and would like to have it just in case.
1990 GXE
Old Apr 8, 2023 | 08:39 PM
chrome91's Avatar
1993 Maxima Key Code | Nissan Forum (nissanforums.com)
to find the code, grab a flashlight, then look behind the glovebox, toward the right side tire.. you'll see a gold colored box with a sticker on it. it's got three numbers on it. the middle set (IIRC) is the correct number. it should be around 7 digits.
now go back outside the car to the keypad.
hit the clear button, then punch that number into your keypad, then you'll hear a long, sustained beep. while it's sounding the beep, enter your NEW key code into it. it has to be at least 3 or 4 numbers, forget the total. when you're done punching it in, just stop pushing buttons and let it sit for a few seconds.
when it gets done beeping, hit the clear button again and punch in the code you entered. it should unlock the doors if they're locked. hit the button with TRK on it and it'll pop the trunk. hit the WDW or whatever button and it will roll down the front windows.
Old Apr 9, 2023 | 08:38 AM
Hectic's Avatar
Getting old will only make you to forget the code, and forget to lift the door handle up when you shut the door, which will prevent you from locking your keys in the car in the first place.
1990 GXE
Andoskyy0130
38
Feb 21, 2009 09:02 PM
tcam0678
Dec 2, 2004 12:27 PM
jeewiz13
Nov 14, 2004 12:48 PM
luniz97
Oct 2, 2002 09:24 AM
avonlea
May 26, 2001 01:00 PM
