Cracked ignition coils
Old Feb 11, 2002 | 07:19 PM
NOMAD92SE's Avatar
My 92SE has been acting up for sometime now. What it does in any gear is that once you accelerate it will feel like it is about to shut off.
Now I've done the search thing on this website and found many different things that it could be. I have changed Air flow sensor, water temerature sensor put water remover in gas tank, although it doesn't get very cold down here in Texas. Long story short does anyone think it could be the ignition coils. I checked the ones on left side and all three of them are cracked. Any help appreciated. Courtesy Nissan here in Texas has them on national backorder.
Old Feb 11, 2002 | 07:50 PM
Mizeree_X's Avatar
Getting back to his roots
Re: Cracked ignition coils
If you have a multimeter, check the resistance of each coil. It should be around 1 Ohm. If it is much higher, then the coil is bad and should be replaced. This is according to my Chilton's. I checked them for the helluvit and mine were all 0.9-1.1 Ohms. Hope that helps.
Old Feb 11, 2002 | 07:56 PM
NOMAD92SE's Avatar
Re: Re: Cracked ignition coils
Cool, I'll give it a try, I just thought if they were cracked they would automatically be bad.
Old Feb 12, 2002 | 11:02 AM
eric93SE's Avatar
REPLACE THEM
Dude if they are cracked then it doesn't matter if they have continutity or not. The high voltage will short to ground and you will loose power and fuel economy! if they have more than 80k on them then go ahead and repalce them. You'll find how much power you've been missing. Order them from courtesy nissan in Texas, they give a %25 discount for org members, just tell them your ordering from the internet and you want the discount (coils should cost about $54 from courtesty).
-Eric
Old Feb 12, 2002 | 05:44 PM
NOMAD92SE's Avatar
Re: REPLACE THEM
-Eric
Courtesy Nissan is about 35 minutes from my house, I called them Monday, and the guy I spoke with said that they are on backorder, he doesn't know when they will be in. He told 57 bucks for each. Guess I'll drive around for a while like this.
Old Jul 22, 2002 | 03:54 PM
1994 se lover
Re: REPLACE THEM
which side is left coils and which side is right coils.? stupid, but honest question..
thanx
Old Jul 23, 2002 | 09:39 AM
poorcollegeboy's Avatar
my front three were cracked and had the same symptoms. CHANGE THE COILS. you will feel a HUGE difference. in the mean time, while you wait for the coils, you could wrap a single layer of electrical tape all around the cracked coils.
Old Jul 23, 2002 | 12:08 PM
atulb84's Avatar
i'm a pretty stupid guy. can someone show me where the coils are on a VE. i remember someone telling me mine were cracked but i didnt know where they were. i know i need to replce but i''m just gonna tape them for now. thanks in advance. pleas dont call me stupid.
Old Jul 23, 2002 | 12:23 PM
NOMAD92SE's Avatar
Re: Re: Re: Cracked ignition coils
They are what your spark plugs are under, there are six (6) of them
3 on the right side of engine and 3 on the left side. If you are standing on the drivers side of car looking towards passenger side.
The left side will be towards the front of car and the right towards the firewall of the car. The left ones have a 10mm bolt to unscrew and make sure you unplug the connectors and should pull right out. The ones on the right side have (2) two 10mm bolts on them. BTW O'reilly Auto here in Texas has them cheapper than Courtesy, but they can only carry the right ones. But Autozone carries the left ones. I have gotten the left ones which were the cracked ones already and it did make a difference I still have to replace the right ones. Well anyway atbul84 I hope that helps you out.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
Andy29
Sep 29, 2015 05:32 AM
zmcneely13
Sep 26, 2015 02:26 PM
