How to remove Washer Nozzle?
Old 02-13-2002, 07:49 AM
spidermike9's Avatar
Can someone tell me how to do this?
spidermike9 is offline
Old 02-13-2002, 08:17 AM
Jedi Knight
nupe500's Avatar
Re: How to remove Washer Nozzle?
WOrd of advice...did you try looking under your hood to see how easy it is to remove one of these...don't want to be a smart *** but noone is going to reply to such a post if you didn't try it by yourself...show us that you made some effort and more people would have replied.
nupe500 is offline
Old 02-13-2002, 09:24 AM
ok here you go for the details...
one of my washer nozzles is clogged (it squirts a little fluid but not much). I failed inspection because of this. I pinched off the hose that goes to the other nozzle to try and unclog the other one but it didn't work too well. So now I am going to just pull the nozzle off and try to un-clog it. My fingers fit in the small hole on the underside of the hood but I can't tell how the nozzle is connected. I pulled on the hose that is connected to it but it does't want to come off and I don't want to break it off.
So, not to be a "wise-***", I will post my question again...How do you remove a washer nozzle?
Does it just unscrew from the hood or does it pop off? I don't want to try and snap it off and end up breaking it.
Old 02-13-2002, 12:14 PM
eric93SE's Avatar
Try using a cotton swab with rubbing alcohol (and if that doesnt work try a stronger solvent). Apply it to the spray nozzle, there might be build up in the holes from waxing the car or something.
eric93SE is offline
Old 02-13-2002, 12:34 PM
dnas420's Avatar
here
there are clips in there holding them in. get some needle nose pliars or somthing similar and pull the pin out and get some washer lights. the high pressure ones. huge diff in spray power
dnas420 is offline
my03maxima
07-28-2024 07:40 AM
doctorpullit
03-29-2016 11:08 AM
RealityCheck
10-02-2015 06:34 PM
jaydot901
09-29-2015 01:18 PM
Max Nu-BE
09-28-2015 10:25 AM
Quick Reply: How to remove Washer Nozzle?
