stupid question??????
Old Feb 13, 2002 | 09:21 PM
93max's Avatar
how do i flush the tranny fluid on my 93 se 5spd? what would be good as tranny fluid?
Old Feb 13, 2002 | 09:29 PM
Jeff92se's Avatar
I'm needing a caw
No it's a good question considering you probably have been reading the procedures on the auto trannies.
You don't "flush" a 5-sp. You simply drain and refill. There is a large 4 sided nut that accepts a 1/2" drive wrench. You simple unscrew that and let the tranny fluid drain. Then you can refill using the fill nut or just fill the recommended(premeasure) amount into the speed sensor hole located on top of the tranny near the firewall(directly under the fuel filter). Amsoil/Redline and Mobil 1 make good synthetic fluids. Check your manual for the proper type and consult a good shop to help you choose the right fluid.
Old Feb 13, 2002 | 09:36 PM
Matt93SE's Avatar
STFU n00b!
whatwhatwhat?! speed sensor hole?!
sonofa*****! I've always just pointed the bottle into the plug on the side of the tranny and smashed the crap out of it until I had most of the oil out... I never thought of the speed sensor!
Old Feb 13, 2002 | 09:43 PM
Jeff92se's Avatar
I'm needing a caw
Haha! yeah we can still learn from each other huh? I might need to consult w/ you on those brackets! hehe.
Yeah speed sensor hole is alot easier. Just use a long clear tube and shove it down the hole. But make sure to PRE-MEASURE THE AMOUNT NEEDED.
Old Feb 13, 2002 | 10:17 PM
JDwyer2821's Avatar
So its as easy as changing the oil I think I am going to switch to amsoil/redline when I get my max back with the remaned tranny. You think that would be smart?
Old Feb 13, 2002 | 10:20 PM
Jeff92se's Avatar
I'm needing a caw
Good idea but break in the tranny for about a 1000 miles first
Old Feb 13, 2002 | 10:39 PM
nismo1989's Avatar
You are the man.
Thanks for the
Old Feb 14, 2002 | 01:12 AM
Bman's Avatar
(Me copies and pastes Jeff's post to text file) Thanks Jeff! I luv this place!
Old Feb 14, 2002 | 01:51 AM
Matt93SE's Avatar
STFU n00b!
Yup.. when you get the tranny back, put some cheapo fluid in it for 2-3k miles. after it's got a decent break-in period, change it to a synthetic MOTOR OIL.. like Mobil 1 SAE 50... use the heaviest motor oil you can find...
run that for a few thousand miles...
Then put in the redline or amsoil..
this was what the tranny shop told me when I had mine rebuilt.. they build trannies for many of the local road racers and drag cars.. they can't be too dumb on the situation.
Old Feb 14, 2002 | 02:31 AM
JDwyer2821's Avatar
I am taking notes on this thread
Old Feb 14, 2002 | 03:06 AM
Matt93SE's Avatar
STFU n00b!
See, we're not a$$hole moderators all the time. only when the kiddies are awake. we come out at night.
Old Feb 14, 2002 | 11:02 AM
Lordrandall's Avatar
Riiiiiight
Old Feb 14, 2002 | 01:39 PM
JDwyer2821's Avatar
hehe thats why more than half my post are after midnight
Old Feb 15, 2002 | 01:36 AM
JDwyer2821's Avatar
What amount are we supposed to put in are max?
Old Feb 15, 2002 | 02:33 PM
Bman's Avatar
4.7L ....just because it's you
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
