auto air conditioning and heater problems
Old Nov 16, 2000 | 02:21 PM
bobg
please help,my 93 gxe will not maintain set temperature and just today the fan blower blows on high only. if you set the temperature at 72 it may omit warm air and then out of no it will blow cold air. i have already tried a differen dash control unit. i know it has a lot sensors and the like but i thought somebody might have an idea.
Old Nov 17, 2000 | 09:57 AM
ryan's Avatar
I am having that same problem and I can't find out wha it is... On mine it also seems to blow out hot air some times down near the feet when the heater and fan are even off.. I would like some advice also....
Old Nov 17, 2000 | 06:54 PM
ryan's Avatar
Any one have any ideas of how to fix this or what it would be??????
Old Nov 17, 2000 | 06:58 PM
FAST4EN's Avatar
I can tell you about the heat thing.....no matter what, there's heat coming off of (or from) your engine and the heat has to go somewhere. Usually it will do this in my max by blowly blowing the hot air through the vent VERY slowly just enough where you can feel the heat coming off of it. The solution: Just put the temp selection on something colder that way the heat will dissipate somewhere else instead of into your cockpit.
Old Nov 18, 2000 | 02:15 PM
DDD
To block the hot air
it's enough to push OFF all the directional buttons on the AC control panel (as for my car - it helps).
Have a pretty cool trips,
DDD
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
egali045
Aug 5, 2015 09:02 AM
