spoiler light
Old Feb 23, 2002 | 07:26 AM
91REDMAX's Avatar
spoiler light
My spoiler light wont come on could i have a short in the wire or do you think its the fuse my other brake lights work any suggestions and how do i change the fuse do i just pull them out and push the new ones in thanks.
Old Feb 23, 2002 | 12:11 PM
«§»Craig B«§»'s Avatar
Re: spoiler light
yes, that would be how you change a fuse, look at teh fuse, there should be a small piece of metal that connects the two "legs" if it's broken then the fuse is burned out, otherwise, it's allright
but that's not your problem, if your other brake lights are working, your spoiler one should too, they are on teh same fuse
have you tried replacing teh bulbs? Just two screws on the cover and you can get to them
Old Feb 23, 2002 | 01:48 PM
maximusSE's Avatar
mine does the same thing, is not a short if your otherones work, and its probably not the bulb, i dont think that i have gotten a clear answer on how to fix it though?
Old Feb 23, 2002 | 06:24 PM
VTECSTALKER's Avatar
my spoiler light did that i just happened to fool around with the wires and harness and they have been working ever since
Old Feb 23, 2002 | 06:32 PM
N34JZ's Avatar
Needs non-Maxima Friends
it probably is the bulb
that what it sounds like to me
Old Feb 23, 2002 | 10:25 PM
XmaximaX's Avatar
My brake lights dont work either, i just leave it alone and took out the cover and everything, it saves weight
Old Feb 24, 2002 | 06:50 AM
tmuscedere's Avatar
Re: spoiler light
I had a car that did that once the problem was where the wire harness bends from opening and closing the trunk. The wire has to bend at one spot. So from opening and closing the trunk it breaks.
Old Apr 24, 2002 | 09:45 PM
Gary95's Avatar
my spoiler brake light is out too
I noticed you guys are referring to your 3rd gens with this problem. Mine is a 4th gen and I just noticed it while checking my new taillight installation. All brake lights work except for the spoiler.
I did manage to find this problem noted in the FAQ, in one particular case being a resistor on the circuit board. Apparently there are several--if one blows, no lights work.
Taking a closeup look at the red LED cover, I noticed an unusual black spot. I'm thinking this might be the blown resistor. I can't believe it would be the wiring... the taillight wiring has nothing to do with the spoiler light--it has it's own connection to the brake light switch.
Old Apr 25, 2002 | 10:31 AM
Brandon90gxe's Avatar
Re: Re: spoiler light
you are teh funny
Old Apr 25, 2002 | 11:53 AM
phat's Avatar
Re: Re: Re: spoiler light
Originally posted by Brandon90gxe
you are teh funny
MY 90 max did the same thing. I found out that i did not have a ground. I just splice that ground wire to another ground wire. That was the end of that problem.
Old Apr 26, 2002 | 06:29 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: my spoiler brake light is out too
3rd gen = 2 light bulbs
4th gen = row of LEDs
Old Apr 27, 2002 | 06:35 PM
Taegost's Avatar
You guys have lights on your spoilers??
I'm jealous!
I really wish I did, because I saw a really neat mod on here a while back about re-wiring the trunk and doing some photoshop editing on a sticker to make the "Maxima" logo on the trunk light up in red when you hit the brakes... I thought that would be neat...
But, I guess I have to do it the hard way... I'm starting to run out of duct tape!
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
jds22
Sep 4, 2015 01:52 PM
