WIRING HARNESS FOR HIDs
i have a 1992 maxima, and have used a few different pairs of 9004 blue HIDs. after several months of use, the high wattage of the headlights fries my wiring harness and one or sometimes both of my headlights will not work, and i need to buy new stock headlight adapters. i know there are kits available that up the power capacity of your car, enabling one to use these newer, blueish headlights. does anyone know a reputable place to get such a kit for a reasonable price? and some place other than ebay because i already have looked there. post replies or email to [email]mrsmooth15@aol.com thanks
Originally posted by «§»Craig B«§»
check my page for a good writeup on how to make your own harness
if you're not up for that, just check local parts stores, they should have something there
You have a write up in the works for the fogs or is it the same?
And is NickMax talking about actual HID or Xenon look alikes??
Originally posted by nismo1989
damn craig you got a write up for everything!
not to mention hid doesnt use stock harness to light it.. it rather use's a ballast
Originally posted by ngthing
but the ballast uses the stock wiring, at least mine does
and the ballast use's a heavy duty wiring to the bulb.<-- whats what meant , when i said it doesnt use stock wiring. up above
I meant how can I have true HID without the $700 kit. Is it possible to rig it up DIY? It seems like you could get the proper wires and bulbs for a lot cheaper...
all the HID kit is, two ballast, two bulbs.. the stock 9006 harness plugs into the ballast.. and the ballast is connected to the d2s/d2r bulb...?
there isnt a way to get real hid, with out that kit.. so i dont know what your confused about
you cannot jerry rig a hid kit...well, you could, but it's not something 99.9% of the people around could do.
the starter and ballast are complex pieces of equipment. you're playing with lots of electrical stuff here, and it's not a good idea to atempt to mess with it.
if you want hids, go buy a kit.
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
