stock alarm
sounds like the ground signal inside the door lock has begun to fail. replace the door lock and it should solve your problem. probably best to call your dealer and talk to them... there may be a smaller (cheaper) part you can purchase to replace the worn parts.
the way the alarm works is that it arms 90 sec after you shut and lock the doors. when you stick your key in the lock and turn the key, there's a contact on the lock mechanism that grounds a disarm wire tied to the alarm. the problem is that that connection gets dirty and worn over time and stops working properly.
oops.. yeah. my bad.. service manual says 30-40 seconds.
somewhere in the troubleshooting section it says to wait 90 seconds before pressing any buttons.. that's where I came up with it.. err something like that.
Re: stock alarm
Originally posted by memphis92se
i have a 92 se and it has the stock alarm but it goes off sometimes just by unlocking the doors and i was wondering how this alarm works, how you turn it on, and what can set it off
thanks rane
thanks rane
Whatever, maybe I did find out the hard way. FYI, the alarm will also sound if someone locked on the inside of the car starts messing with the pull-up door locks. So fancy. Yep.
Re: stock alarm
are you using a after market alarm when the fact alarm goes off?
or does it go off when you unlock with the key?
because it does make a difference in diagnosing your problem
thanks rane
thanks rane
04-16-2020 05:15 AM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
