please help with problem?
Old Mar 11, 2002 | 08:39 PM
93max's Avatar
i got a problem with power with my VE.
when i was on the ice/snow (backroad) i was pulling through the gears (i hit 70 for the first time in 2nd i think well i was so happy)when im on the road (no ice) the car won't go past 4500 rpm (cause it had a load on the engine)i changed the plugs to boshche (sp?) platinum 4 tip (does it really matter if it's ngk) didn't change my fuel filter yet. What wrong with my car? i drove my mom's 97 v6 camry and thought it was fast. can my cat be cloged? please any help
Old Mar 11, 2002 | 09:01 PM
skatanic28's Avatar
o2 sensor or somethin like that?
could be in safe mode or low-performance mode
whatever that thing is
im not really sure but i tried
Old Mar 11, 2002 | 09:33 PM
Matt93SE's Avatar
STFU n00b!
1. if you hit 70 in 2nd gear, then you were well past 4500 rpm..
2. the description of the problem is very vague, can't tell hardly what you're trying to say.
Old Mar 12, 2002 | 06:47 AM
93max's Avatar
thanx for replpying
i hit 70 while i was on the ice/snow (no load; tires were spinning freely)
i posted this a while ago too. (on the street)in first it would goto 4500 and would not want to pull any more.second would do the same. it would pull up to 3700 easily then slow down to 4500 then it really doesn't pull and probably redline in 30 seconds (literally). can it be the timing
Old Mar 12, 2002 | 09:02 PM
93max's Avatar
bump
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
