Anyone clean their MAF?
Old Mar 12, 2002 | 06:08 PM
Sith's Avatar
I pulled mine off and couldn't get the screen off to wipe it with a q-tip. Also what did you use? Alcohol or Throttle Body cleaner?
The screens had some black residue on them that i got off with a just a q-tip the filaments look pretty clean though.
Also, there was a little puddle of oil sitting in the tube just behind the maf when i pulled it off, just in a little puddle. Bad?
Old Mar 12, 2002 | 06:13 PM
ChrisCheezer's Avatar
i cut my screen out
he he but ill try and clean it thisweekend and take pics
Old Mar 12, 2002 | 09:36 PM
nismo1989's Avatar
Badaxxima did it. Ask him. Or, do a SEARCH adn you'll find a couple of recent threads on the topic, I'm sure of it. Good luck, and be careful. That's an expensive part you're toyin with...
Old Mar 12, 2002 | 09:51 PM
Sith's Avatar
i searched and came up with nothing
but it's all goood
i just did what i found in one thread that matt said and bought electrical contact cleaner and sprayed it down.
everything looks ok. No borken filaments
Old Mar 13, 2002 | 06:04 AM
Badaxxima's Avatar
but it's all goood
everything looks ok. No broken filaments
I sprayed Carb Cleaner on a Q-tip and wiped it down, use either electrical contact cleaner or Alcohol (like Matt said). I pryed the screen out with a screwdriver and thought I had damaged it so I left it out. It was actually okay but I haven't had it in there in awhile. Seemed to make a miniscule difference in throttle response, but no ill side effects yet. I had the same black residue on my MAF screen, no oil though.
Old Mar 13, 2002 | 07:10 AM
Sith's Avatar
how do you tell if you have a K&N drop-in?
cause the filter smells oiled and the oil behind the maf is kinda reddish in color. and the screens on the maf if i smelled them they smelled oiled.
Old Mar 13, 2002 | 07:53 AM
whitymax's Avatar
the k/n is a reddish color.
Old Mar 13, 2002 | 07:54 AM
damn i thought i was EZer
you need a Q tip? i cant just spray it down with the electrical contact spray?
Old Mar 13, 2002 | 04:49 PM
Sith's Avatar
It's reddish with no writing other than Made In Korea
but my Napa one in my 91 gxe is reddish too.
Old Mar 13, 2002 | 07:18 PM
thebull's Avatar
when i took my intake all apart i couldnt even get the MAF off of the black plastic tubing that connects to the intake manifold. it could be twisted around, but i couldnt pop it off. does it need to be lined up somehow to be taken off?? my screen was pretty dirty too. i just sprayed some throttle body cleaner on a towel and wiped it off. is ther any way to get that screen off without damaging it or the MAF? that sceening is pretty fragile.
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
