power steering on my 1991 maxima was very stiff..
. this morning i moved the car but didnt let it warm up b4 i drove her... I tried to turn and leave the curb and it was really hard to move... as though i didnt have any power assistant.. After i drove a few feet it became loose..but when i stopped it was stiff once more... after 10 miles of driving it came back to normal... I also felt and heard a noise when turning.. probably the hydrolics.. Could all this be caused from all the cold weather from this morning..?
Or is it more mechanical...
If So How much for a new power steering pump and other parts and labor.????
anyone can help give me an answer?
. this morning i moved the car but didnt let it warm up b4 i drove her... I tried to turn and leave the curb and it was really hard to move... as though i didnt have any power assistant.. After i drove a few feet it became loose..but when i stopped it was stiff once more... after 10 miles of driving it came back to normal... I also felt and heard a noise when turning.. probably the hydrolics.. Could all this be caused from all the cold weather from this morning..?Or is it more mechanical...
I don't have an answer, but I do have sympathy... I get the exact same thing. When I first start up, any low-speed corners I have 0 power steering. Well, not ALL the time, only occasionally, and mostly when it's cold.Originally posted by crazy4maxima
But as soon as I leave my driveway, it's fine, or if I let it warm up first.
Damn, and this whole time I thought I was the only one
I wonder if this could be thrown in with the locks/exhaust stud thing as a common problem or not? Guess we'll see, eh?
Before you go spending all that money, you might just try changing the fluid. It could have some water in it or something. I think if it was pure powersteering fluid, it wouldn't freeze to easy. Actually, now that I think of it, it's more than likely air than water....just like when your clutch or brakes get mushy. It could be that the pump is allowing air in if it's leaking,....kinda like your water pump can do. But I would suggest just changing the fluid first and see if the problem goes away....at least temporarily.
Gene
Gene
Quote:
Gene
I'll do that. For me, it's not really a big problem, during the summer if it happens, if I fill the reservoir all the way to the top, it's fine for the entire summer... But I did notice about 2 weeks ago that I was totally out of fluid, which I noticed because the pump started making a noise... When I get it back from my bro I'm going to check it again... I hope it's something simple like a hose leaking if it is that at all Originally posted by rcrdps
Gene
