A question for Fast4en(reguarding the udp)
Old Nov 21, 2000 | 05:12 PM
MILLENIUM MAX
I was just wondering if the underdrive pulleyes affected your audio system in anyway,because i plan on doing this mod soon.Right know i have 2 tens,4 tweeters,and a 2 channel 500watt amp,so will this mod affect my sound in anyway?
Old Nov 21, 2000 | 05:43 PM
FAST4EN's Avatar
Well since you only have 500W amp running the subs, you should be fine. I bought an additional battery because all 3 of my amps put an enourmous strain on the alternator, let alone when I put the UR pulley on, the gauges were hardly lit when I had the A/C and/or stereo on. The 2nd battery got things back to normal and you notice a big difference with the new UR pulley. The car will "pull/accelerate" a lot harder and you will definately notice a difference even though it's only like a 6-8 hp gain, but I think its worth every penny.
The reason I got the UR Pulley (knowing about the stereo/alternator complications) was for performance. When I go out to the strip (100 miles west of Omaha) I take all of that stuff out (subs/amps/cap/2nd battery) for weight reasons. I kinda like running without all the stereo stuff because the MAX seems so nimble and light (with my modifications), as if it had lost half of it's weight.
Any questions? Just Post 'em
Old Nov 21, 2000 | 05:50 PM
MILLENIUM MAX
Ok so your saying that you put an additional battery in your trunk and hooked your amps up to it right.
Old Nov 21, 2000 | 05:55 PM
FAST4EN's Avatar
Re: ???
Right...but its only in there whenever I have my subs in there, which is only some of the time. Why do you ask?
Old Nov 21, 2000 | 06:10 PM
MILLENIUM MAX
no i just wanted to make sure i understud this correctly,and thanks for the info
Old Nov 21, 2000 | 06:15 PM
FAST4EN's Avatar
Sure anytime. As for a bettey, just ask any small electronics store (not best buy circuit city, etc) about doing this. They all have different prices. As I recall, I think that my battery was about $200, the cap was $??? and about $150 for install and cables.
Old Nov 21, 2000 | 08:51 PM
CandiMan's Avatar
Say Candyman 5 times
When I installed a UDP on my VE>>>>
I did a electrical/charging system check before and after the UDP was installed, there was no difference between the two test. Keep in mind I have no audio mods (yet), so I'm not too sure how it would affect you audio guys
Old Nov 21, 2000 | 09:35 PM
block's Avatar
how much was the udp ? and how much to install? easy to install myself?
Old Nov 22, 2000 | 12:28 PM
bmxsteve's Avatar
Im interested in a UR pulley too...are there any side effects to having one of these on? Does it affect anything else in the car??? Had any problems with it? Whats maintance like? Thanks, Steve
Old Nov 22, 2000 | 12:36 PM
JeffesonM's Avatar
living out of a maxima...
Where does the pulley add power... low end or high end? Will this give me noticible increase in acceleration? What's the price and how hard is it to install? Sorry about all the ???
Old Nov 22, 2000 | 04:40 PM
FAST4EN's Avatar
Go here for the answer to your questions: http://integra.vtec.net/geeser/megamax/UDP.html
If you have an Auto, there's a lot of work involved, but a manual maxima is pretty simple. I have a local import shop put it on because I thought that it was over my head. They put it on for about $100 +tax. The UR Pulley from Courtesy Nissan is $190.
I'm leaving For Texas tonight, So I'll be back on sunday
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
