Allignment or???
Old Mar 22, 2002 | 07:01 AM
bjyang
Allignment or???
my car swerves left and right but only on higher roads...like a bridge or something. I kno fo sure my allignment is bad but is the bad allignment causing my car to swerve left and right on windy and high roads???
your help is appreciated
bj
Old Mar 22, 2002 | 07:17 AM
Taegost's Avatar
Re: Allignment or???
bj
Ermmm, windy and high roads?
WIND will cause your car to swerve...
And high roads generally have a lot of WIND...
Which will cause your car to swerve...
Semi's cause a lot of WIND too...
Old Mar 22, 2002 | 07:31 AM
bjyang
i kno that but....my car swerves bad. Like im drivin drunk or something!!! Even with all my force i still cant control the swerving!
i need to get an alignmnt really bad too but do u think the alignment should at least help a little.
Old Mar 22, 2002 | 09:10 AM
Taegost's Avatar
Should help a little, but I know wind plays a MAJOR part in it...
When I lived in Chicago it could push my car over a lane and then back without me having to do anything, and sometimes the wind here does that...
Also happens a bit on Rt. 77 thru the Apps, too
If you need an alignment done, get it done, but there's nothing you can do for the wind except load your trunk and every nook and cranny in your vehicle with cement
Old Mar 22, 2002 | 05:22 PM
lowflyer's Avatar
If the car is stable at any other time, then I would say the road you were on was causing the swerving, but if this is a common occurance, then do the alignment. When they are in there, they will check the outer tie rod ends to see if the ball joint there has come apart and causing the unstable steering. Good luck.
Old Mar 23, 2002 | 10:36 AM
RosenKen's Avatar
Probably worn-down ruts in the road. Do you have stock rims/tires? If you have larger rims/tires, they tend to follow the ruts in the road and will cause the car to swerve a bit left and right as you drift over the ruts a bit.
Old Mar 25, 2002 | 07:58 AM
bjyang
i have 17's but rte now only the stocks are on. I got a new tie rod when i put in the new clutch. I kno it could be a lot of things...but first im going to get an alignment done liek i should've done long long ago so i can slap my rims back on w/o eating the inner thread up. w ell..thankx anyways
bj
Old Mar 26, 2002 | 05:40 AM
phat's Avatar
bj
Alignment make your car swerves either to the left or to the right. If your car sway left and right it may be your front suspension part worn out. Is the new tie rod tight? Jack your car up and hold the tire-push and pull on it to see wheather or not you have any play in it. Is the lug nuts tight?
Old Mar 26, 2002 | 07:06 AM
flyry110's Avatar
road round will affect this, especially if you've lowered your car and have wider tires. on the turnpike i stay in the left or right lane. never the middle cause it's got this tar strip. anyway, it makes my car pull all over the place.
Old Mar 26, 2002 | 08:32 AM
bjyang
i will do that....once it gets a lil warmer. wi weather is still kinda chilly!
Old Mar 26, 2002 | 09:11 AM
Taegost's Avatar
Err, wi=Wisconsin?
I still stand firm on my belief that it's the wind, especially if you're in Wisconsin. I used to live right off Lake Michigan, and from what you're describing, sounds exactly like what WIND will do to a Max, or ANY vehicle besides a cement truck.
If you have alignment problems, then get them fixed, but I am 100% positive that you'll STILL have the problem, especially on high and windy roads (high roads = wind)
So get fixed what needs to be done, and welcome to the US
DAVE Sz
Apr 13, 2004 11:02 AM
Greg 88 Floater
Aug 19, 2003 02:13 PM
JUDE
Apr 10, 2002 10:58 AM
amixam69
Jan 3, 2001 07:08 AM
