Turbo??
Turbo??
Hey I have a 91 Maxima ... I would like to know what I need to Turbo Charge my car... I have a Garret t3 Turbo so far.. I need to know what else I will need I heard I will need the 300ZX Exhaust Manifold...a possible Supra TT fuel pump.. and some other stuff... let me know what I will need!!!! Please
man..i can save you hundreds of dollars.
You said you already have the t3 turbo already right? Thats all you need, nothing else.
Put the t3 under your hood somewhere, just stick it somewhere, thats all.
Now you have to be careful how you word your sentences for the rest of your life. Tell people that you got a turbo under the hood. Don't tell people it's turbocharged.
Now you'll definitely get alot of people asking for pics, When they ask for pics of that turbo under your hood, BAM..bust it out on them. You ain't lying, you really got a turbo under the hood.
Chances are with a 'turbo under the hood' you could be the next maxima of the month.
hey i should do that, i have a turbo from an audi a4 layin on top of my TV. maybe ill just stick it in my engine and say i got a turbo.
matter a fact, i think i will
(I didn't really go out and jump on my muffler, what do u think i am crazy?)
Originally posted by JoJo428m
Sudesh, I take it you like to joke around w/ things. Just like when you said to jump on my muffler. I'm gettin you back for that one.
HAHAH!!
Brandon, i'll take $29.95 for the turbo setup i custon fabricated for your car. I'm not as expensive as the guys who do it for $4,000.
LOL.. duud, ill pay you 5 cents. becaquse you didnt tell me explictly how i should mount it!!!! i mean, damn if your gonan do a write up, you should hella like tell me every little step so i dont have to think on my own, OK?!?!
I thought it just will hang there by itself
man, im gonna get flamed n00b style on this one heh. but i have came up with a few simple piping layouts that i will be working with. note this is just just the piping, i would also think 300z injecotrs/fuel pump, jwt tuned ecu etc. and i came up with these for the ve...soo......
i will be working with #3, using an aftermarket ypipe cut down and weld on a t3 flange.
http://www.roadraceengineering.com/h...eekerparts.htm
go easy on me
go easy on me
hey well its a start, but a few observances on my part....
#1 looks like it will most likely not clear the firewall for the second turbo on the rear bank
#2 looks like it'll have hood clearance issues
#3 looks to have some undercar clearance issues
but hey its a start!!
Originally posted by Dummy
heh yeah, it doesnt look to clear the firewall, when the piping is made it will be made to go horizontal from the trubo, not going up, heh, i just couldnt really draw it like that cause you wouldnt be able to see it. but yeah.....did that make any sense? i expect to turbo to be right infront of the firewall. just hope it doesnt hit against it at times.
oh yeah, and the under hood issues....well i guess i was kinda designing from my vg, havnt gotten a close look at a ve, ill make room
Number 3 looks pretty good except mount the turbo in the front. With all that extra piping you're gonna have a lot of lag. Also it would be easier to work an intercooler into the system. Nice drawings, btw.
PS: RRE has killer prices on intercoolers and DIY stuff..
thanks, but i dont think i totally understand, what do you mean i should put it in the front, i dont think there should be a problem with lag if i have the exhaust from both manifolds flowing to the turbo, it should spool nicely....but yea, i dont think i understand
edit: new drawing comming soon.
I think Mike is saying with all that extra pipiing it'll take longer for the "charge" to reach the TB and "make power", when you design the charge piping it should be as short as possible with little bends.
Originally posted by Jeff92se
#3 won't work unless you pull the turbo up at least 10-12".
heh,and i see what mike is talking about now, but it shouldnt be a problem
what about this? its as close as i think i can get it
heh,
btw what engine do you have? ve or vg
Originally posted by mykizism
why dont you mount the turbo, where it is stock,(in terms of the maxima) in front of the car..
not totally sure though, but i still think it would be much different.
thats the beauty of the "crossover pipe"....IMO thats one of the advantages of turboing the VG....the parts are already available(off the Z31), both manifolds and crossover can be had for less than $200!
i think it would be harder to mount it in front cause i would have to have the exhaust run to the front then to the back
true, but you still have to deal with wiring issues...turboing the current VG in our Maxs to me seems much easier and the 9:1 should be good for boost into the mid/high teens. IMO, the z31-t engine swap is just more unecessary trouble.
or the complete engine for about 600 shipped ^__^
look harder, those engines are everywhere
Those are neat pipe drawings. How do you make those?
Anyway, here is a big hint. 3-gen VEs and 4-gen VQs are very similar from a layout standpoint. So if you SeArCh what those guys are doing for turbo installs, you could make some really neat drawings. :P
hmm.... something kinda like this? or different?
400 for both turbos, 1000 for the piping and custom manifold. i still need a rising rate fpr, and fmu. I was thinking about snagging a 4th gen FMU (my buddy needs to upgrade). so right now it's at 2000 bucks. that's BEFORE clutch, fuel pump, and a bunch of other goodies. . .. i'm hoping to keep it under 3000. if you want a pair of small turbos, they're about 4-500 a pair on www.twinturbo.net you could split the pair with a buddy if you don't want to run a ton of boost.
Originally posted by flyry110
mine's not quite that expensive
ENGINE DISPLACEMENT COMPRESSOR TRIM TURBINE TRIM TURBINE HSG
60-100 CID T3-50 Trim T3 Standard .36/.48
100-150 CID T3-Super 60 T3 Standard .48/.63
150-200 CID T3-Super 60 T3 Standard .63/.82
200-250 CID T4-S3 Trim T4 “O” Trim .58/.69
1) Good luck w/ the oil drains
2) To get the turbos high enough probably means custom manifolds. That will blow your budget.
true, but also remember post '88 300zs used T25s and 1/4th mile times remained rather similar. and HP increased 5hp! I know it says a T3 is optimum, but low boost setups should be fine with a T25, you should be able to play around with the AR on it though I think...I'm not 100% but as long as you can get the AR to .84 you'll be fine!
Originally posted by jim90gxe
a single T25 is too small..
I'm not expert, don't shoot me
What's this?? A constructive thread about turboing the Max?!?!? My brain can't handle this! I will attempt to return this thread to normal:
