Does anyone has heating problem
Old Mar 27, 2002 | 12:14 PM
Suya's Avatar
Hello all. Just wondering. If anyone has experienced heating problem. My engine gets heated when I got stuck in traffic. I looked at under the hood. I find that the cooling fan is not working. I moved around the cable that goes to heat sensor. After I moved the cable the fan started to work again. It happens quite frequently. Does anyone has this problem? I thought of changing the cable but it looks too complicated. Is this just the cable of my heat sensor has problem?
Old Mar 28, 2002 | 06:35 AM
time2reup's Avatar
Re: Does anyone has heating problem
Try using the search man, you will find posts to keep you up till 5am on heating problems and solutions.....LOL
Old Mar 28, 2002 | 07:54 AM
Matt93SE's Avatar
STFU n00b!
problem is most likely a corroded connector on the sensor..
weird thing is that if you disconnect the sensor, the fans should come on automatically- as a safeguard.
check the resistance on the sensor with a multimeter..
cold engine (70F), it should be about 2.5k ohms.
warm (125F), should be 680 to 1000 ohms.
hot engine (175), it should be about 300-330 ohms.
if it's no good, or the connection is corroded badly, you need to buy a new sensor.. they're not terribly expensive.
Old Mar 28, 2002 | 03:40 PM
Suya's Avatar
I think the heat sensor has rust. So, I believe I need to clean it. Thanks.a
Old Mar 28, 2002 | 07:20 PM
Brandon90gxe's Avatar
Re: Re: Does anyone has heating problem
i havent seen this topic posted before...
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
slowlifer
Sep 8, 2015 05:53 AM
