rear door -- hard to open
Re: rear door -- hard to open
Originally posted by thebull
my rear door is very hard to open and close. i tryed squirting alot of wd40 in there but it didnt do anything. any suggestions?
There may be some special grease that you are supposed to use.
Is it just very stiff like it needs lube? Make sure there's nothing bent out of shape or binding first. Check the mechanism parts for rust and such too. I'd use something heavier than WD40 for the long-term (ie, grease) WD40 doesn't stick around for very long and thins out existing grease.
Actually, the rear doors are probably in fine shape.. the tensioners on the front ones are worn so much because you use them every day that you think that's "normal". then when you use the rear doors (once every couple days like me), they feel stiff and hard to open.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
My friends all joke about my ghetto doors when it's my turn to drive... But we're so used to it now, the only people it throw off still are people new to my Max.
I prolly should spray it with something, huh?
vingodine
45
05-21-2016 12:46 PM
King_Ten_Ahead
09-30-2015 04:27 PM
Huttig2009
09-25-2015 03:31 PM
MaximaDrvr
08-19-2015 08:20 PM
shaunkey1
08-18-2015 10:09 PM
