UDP harmful???
Old Apr 4, 2002 | 03:30 PM
poorcollegeboy's Avatar
UDP harmful???
i know i have been pretty negative with mods lately but....
the stock crankshaft pulley has a harmonic balancer which prevents the crankshaft from cracking or oil pump from breaking at certain rpms/frequencies.
where are the harmonic balancer on the udps???
although the only known incidences of this happening are on honduhs and mazdas.... it's somthing that could/should be looked into.
has anybody noticed any extra vibrations while slamming on the pedal (especially with an asp udp)?
Old Apr 4, 2002 | 06:07 PM
Aaron92SE's Avatar
NWP Engineering.com
Re: UDP harmful???
My engine revs very smooth, especially after I installed my ASP UDP. This matter has been talked about sometime in the past. Try searching to see what you can find.
Old Apr 4, 2002 | 06:13 PM
maxmizd27's Avatar
No prob here either. Rev's up fast as all get out. Especially with my new y-pipe.
Old Apr 4, 2002 | 10:37 PM
mykizism's Avatar
i like my udp
Old Apr 4, 2002 | 11:13 PM
Matt93SE's Avatar
STFU n00b!
do a search on the subject. it's been mentioned several times before.
the OEM pulley has rubber in it to save weight, not to reduce vibrations.. There's not enough rubber in it to do that.. but it saves a couple pounds over making the entire thing out of solid steel.
and for the record, I have yet to see any maxima engine, VG, VE, or VQ have a problem with an aftermarket pulley.
Old Apr 4, 2002 | 11:56 PM
Nismo87SE's Avatar
I believe my car is the only one that had a problem with the UDP. I know now why it had a problem though. My car was made after 4/87 which was when nissan switched to a different crankshaft in the VG30E's. The shorter snout is was caused the gap between the pulley and crankpulley bolt. The gap was only like 1/8 or 4mm, but techincally speaking the 2nd gen UR pulley does fit the 85-87 maximas made before 4/87 (mine was made 5/87). Other than my misforune no one else had a problem whatsoever .
EDIT: My problem was not dampner related as Kaleb pointed out (Good looking out Kaleb). Mine was a fitment issue, as long as there is no space between the UDP and pulley washer there will be no problem.
Old Apr 5, 2002 | 12:04 AM
kaleb's Avatar
And your misfortune was completely unrelated to dampening issues, so please try not to confuse the newbies.
Also, I had a complete set of engine internals balanced to 0.25 grams with the UR UDP and there was no significant balancing problem w/ the crankshaft. Because it's internally balanced and all that good stuff.
-Kaleb
Morfeus17
Mar 31, 2001 02:21 PM
y2kse
Feb 25, 2001 08:47 PM
Andrew91SE
Nov 26, 2000 03:05 AM
ohboiya
Oct 9, 2000 12:23 PM
