Ok Tokico's or Koni's
Old Nov 24, 2000 | 12:47 AM
MILLENIUM MAX
Ok guys i'm looking to buy a pair of performance shocks next week and was wondering which one's should i get.I'm looking for great performing shocks that's easy to install and have good quality.I heard that the Koni's are adjustable,so does this mean hight adjustable or ride quality adjustable,and if i do get the koni shocks i assume that there compatible with the Tokico struts that i have.Well guys i would appreciate the advise because i'm looking to get the best handling not the worst,o incase your wondering what springs i'm planning on its between the suspension tec's or the intrax springs.
Old Nov 24, 2000 | 10:54 AM
Maximamike's Avatar
If you have the cash, Koni's all the way.
Old Nov 24, 2000 | 11:20 AM
Matt93SE's Avatar
STFU n00b!
Well, if you want the best handling, your best bet is to go with Eibachs and Konis..
Konis are more difficult to install than the tokicos, as you need a set of front struts that you can cut into pieces. they were designed to be fitted on OEM struts, so I don't know whether they'll fit on your tokicos or not. BUT.. the konis are adjustable and are much better performers than the tokico.
eibach springs don't provide as much of a drop as the others, but they perform better than the intrax or ST.. if you're looking for handling, they're the way to go.
Old Nov 24, 2000 | 12:54 PM
MILLENIUM MAX
Thanks guys
AcuraLegend
Oct 17, 2016 08:47 PM
Peter Paul
Jan 2, 2016 05:18 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
