Interesting results from first time at track...
It was my first time at the track and here are my four runs:
Run 1:
1994 Nissan Maxima GXE Automatic. Front tires at 32, rear at 44. Spare and jack removed. Full interior. Stock intake, stock exhaust, and some special tuning. :-D
R/T .966
60' 3.005
1/4 18.090
MPH 79.87
I spun the tires through first and into second gear, then the tires hooked up and so the tranny shifted back into first. What a nightmare.
Run 2:
Same as above but front tires at 25.
R/T 1.160
60' 2.407
1/4 16.611
MPH 81.30
Better traction, manual shifting.
Run 3:
Same as above but front tires at 22.
R/T .957
60' 2.358
1/4 16.379
MPH 82.59
Getting there.
Run 4:
Same as above.
R/T .727
60' 2.388
1/4 16.346
MPH 82.51
I was happy.
This was all at a track which is 492 feet above sea level with the temperatures in the 40's and the humidity not too bad.
Run 1:
R/T .966
60' 3.005
1/4 18.090
MPH 79.87
Run 2:
R/T 1.160
60' 2.407
1/4 16.611
MPH 81.30
Run 3:
R/T .957
60' 2.358
1/4 16.379
MPH 82.59
Getting there.
Run 4:
Same as above.
R/T .727
60' 2.388
1/4 16.346
MPH 82.51
I was happy.
yeah that does sound really quick and those traps are kinda low, my best is 16.224 @ 84...thats really good though for bone stock!
FFXmax is the only other "freak" VG auto I've seen, he ran 16.5's with just intake when we were at the track a few months ago! good times though!!
I don't have any mods to really speak of besides a courtesy FSTB, but here is what I did to attain these times:
1. Ignition timing is somewhere in the range of 15-20 degrees. I advanced it the ghetto way without a timing light. I use 93 Octane.
2. I adjusted the throttle cable today and there was a lot of slack in it. As a result, I believe I am now achieving true WOT.
3. Tires at 22 in front and 44 in back is a must.
4. Spare and jack were tossed.
5. During staging I had to spin the tires after the burn out box to get the water and rocks off my tires.
6. I launch in 1st gear (yes it's an auto) at around 1500-2000 RPM. When the lights do their thing, I floor it.
7. I put the tranny in power mode, but I shifted it manually.
8. After each run I propped open the hood and turned the car off. Pushing the car through the staging lanes is a good idea too.
Damn good times
You might want to get 2 extra 15in wheels and throw some 205/50-15s on them. That by itself should drop you to a solid 16.0-16.2s in the same conditions with no other mods. If you had a Y pipe and the same conditions chances are you could have broke 15's.
HAHAHAHAHA
man where do you make up those times! i saw you running 12's all day! dont be nice just becasue you have a sway bar and most dont. we all know it gives like 100 hp. Just kidding, it was good to finally meet you in person, and i know you would like to have my car! lol see you on the 19th!
Re: HAHAHAHAHA
Finkle
09-27-2015 09:53 PM
MaximaDrvr
08-19-2015 08:20 PM
Team STILLEN
08-10-2015 04:29 PM
