need help quick
Old Apr 9, 2002 | 06:50 AM
93max's Avatar
need help quick
trying to use my corner light as a switch for my fogs, now my dash lights and corners are out. the little corner bulb broke is that the problem. can it be relays or a fuse (which one).
on school computer so can't stay around to long and my home comp doesn't work right now
Old Apr 10, 2002 | 06:44 AM
93max's Avatar
bump
are there any other fuses or relays (how do u know if they go bad) i can check.
Old Apr 10, 2002 | 06:52 AM
Taegost's Avatar
I believe that if one of the lights goes out, so does your dash, kinda like a warning light for people who aren't related to the Flash, so they know when a brake light is out w/out having to do that running so fast the world turns around backwards thing...
Fuses you can usually tell because either A) They're black, or have black spots, especially over the filament, or B) there isn't a filament/sometimes accompanied by a soft rattling noise if you shake it (Never seen a car fuse that did that, but then again, when I kill a fuse, it's usually pretty bad...)
The Haynes manual tells where all the fuses and relays are, I know there is a set of each under the steering column, and under the hood I believe there are 2 relay boxes.
Old Apr 10, 2002 | 07:14 AM
93max's Avatar
thanx for helping
i guess search is faster. people say check the brake fuse.
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
