indiglo gauges
Re: indiglo gauges
Originally posted by mm187
hey fellas
I bought some indiglo gauges from cutommaxima.com. they just sended it to me with instructions.
how do i wire them up?
to the 12 volt?
any help is apreciated.
hey fellas
to the 12 volt?
Re: Re: Re: indiglo gauges
yeah but how do i wire them?
12 volt?
relay?
how do the people that have the indiglo gauges set it up?
12 volt?
relay?
I wired up the wires to the wiring harness on the stock fog light switch. Red to Red/Yellow, Ground to Ground.-James92SE
I, to, Bought my Indiglo Gauges from CustomMaxima.com. I seriously recommend that site to all Maxima owners.
Now on the Indiglos, Mine are installed. Your best bet is to pay someone to prefesionally do them. because if you mess anything up, (Ecspecially the Needles or break them on the guages)your pretty much screwed.
Just my advice
But then again, They will charge an arm and a leg to install them. They charged me 75$. And thats how much the Indiglos were.
Just my advice
Just my advice
Just my advice
where did you get them installed?
I want to hook them up my self but i dont know how
direct to 12volt? or relay? I dont have fog lights like the other guy.He had it connected to that.
You saw in my post that I wired up the Red indiglo wire to the Red/Yellow wire on the fog light harness. And then I wired up Black to Black.
Look at your harness for your clock, or your defogger switch, or any of those harnesses around the steering wheel. Find a red/yellow wire, splice into that, and then find a ground wire (black) and splice into that. I know the defogger and clock both have these wires. So I'd suggest trying those.
There is no need for relay's or anything like that...
for anyone with indiglos, does your dimmer that came w/ them work? mine works sometimes, but most of the time it acts like its turned up all the way, even though i have the switch all the way down. i'm thinking it's just the switch, because i wired it up lots of different ways, but it still does it.
Originally posted by James92SE
Nope my dimmer works fine. Although, when I have it on blue....it makes this weird faint buzzing sound and drives me insane. The green doesnt do it though!
mine does that little humming sound, but i can't hear it, unless the engine and radio are off.
I hooked mine up to the light that is around the cigarette lighter. That way the indiglos come on when I turn my lights on.
when u splice some thing off dont u want to hook the red (+) up to the + line u are running off of but wouldnt u want to hook the negitve up to the other end the + line making a series cirucit and not parell by hooking the + up to the + and the - up to the -
so it looks like this
(+)__________ (+)_______ _________(+)
_|_ | |
| | +newdevice-
new device or
(-)_________ (-)___________________________
_|_
new device
_|_ | |
| | +newdevice-
new device or
_|_
new device
220k+ A32
18
09-22-2015 11:39 AM
RWCreative
09-21-2015 11:01 AM
