Help!! My rear spoiler is coming off..
Old Nov 26, 2000 | 09:26 AM
92ZexMaximaSE's Avatar
My 92 SE rear stock spoiler is coming off on one side.. It looks like there is an adhesive that keeps it attached to the trunk lid. Anyone know what I can use to re-attach it? I don't want to take it into the shop and have them do it if I can do it myself.. Thanks.. Any help is appreciated.
Old Nov 26, 2000 | 10:38 AM
Blu Max's Avatar
Do a search, we talked about this one weeks ago,I just used doubled sided tape and krazy glue on the spoiler side, and it's been holdin' it pretty good.
Old Nov 26, 2000 | 01:48 PM
MSK
RE spoilser fix
I think the real fix is to take it out, clean or replace the metal plates that holds it and put it back. I am not sure dealer sells the plate separately. I have seen alot of people just replaced it. Update us.
MSK 90SE
Old Nov 26, 2000 | 01:54 PM
93 SE's Avatar
if your gonna use an adhesive,i suggest you use epoxy it it is the strongest and hardens up like plastic when it dries
Old Nov 26, 2000 | 02:00 PM
MSK
RE
I agree
MSK 90SE
Old Nov 26, 2000 | 02:17 PM
93 SE's Avatar
the epoxy i used was so strong.. it made my last car [89 mx-6] last a whole summer before the tranny gave out ...i had epoxy on a crack on the radiator next to the cap...it held on strong i was suprized it lasted that long..so im positive it will hold a spoiler
Old Nov 26, 2000 | 07:03 PM
MSK
RE epoxy
That sounds good What brand of epoxy is that?
MSK 90SE
Old Nov 26, 2000 | 08:06 PM
FAST4EN's Avatar
Re: RE epoxy
Doesn't matter. If you want a temporary fix, just use superglue or even duct tape. Because if you can't "duggit", then "fuggit"! Haha (not funny)
Old Nov 26, 2000 | 08:12 PM
93 SE's Avatar
i think its qualco....if you do get epoxy get the one made to hold metal....it should turn the color gray when mixed not clear ...it might also be called industrial strength. i got mine at National wholesale liquidators....im not sure if they have those stores across the country though..
Old Nov 26, 2000 | 08:30 PM
CandiMan's Avatar
Say Candyman 5 times
The true fix
Now I know some wont agree, but the true fix is to replace. The OEM spoiler has a metal piece attach to it and attach to this metal piece are some sort of plugs that go thru holes in the trunk. Also, it has double sided tape along the outter part of the spoiler. Now since the double sided tape not a true weather resistant product, over time the metal bracket piece starts to rust, hence seperating from the trunk. Try this, open your trunk and tap the area where it's seperating and see if any rust pieces falls out. I just replaced my OEM spoiler with another OEM piece. Didn't really like all those aftermarket spoliers out there. When I installed my new spoiler I used a small bead of clear silicone along the mating surface to help seal it better. Good luck.
Wolvee
Apr 20, 2018 05:34 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
BobMax
Aug 15, 2015 12:35 PM
Tommy6905
Aug 14, 2015 11:54 AM
