maxima pictures
#43
Originally posted by Maximan190
wow looks great ng but personally i liked the stillen front lip better; rest of the car is awesome...the white one would look good with some black tint
the white one is getting some tint soon
#48
Originally posted by nismo1989
So are you going to answer my question or not? Is it privelaged information?? I wanted to know about the fabrication on the white one, how you smoothed out the holes from removing the hollow piece that went there...
#49
Re: Re: hey
Originally posted by Shugarhi
there is gray trim on clear cornerS?
http://www.geocities.com/skymaxse/clearcorners.htm
#50
Re: Re: Re: hey
Originally posted by SkyMax
Check out this page I made.. It shows you how the clear corners look with the trim painted black.
#52
#57
Originally posted by fastmax92
i donno mine came that way!! I can sell you one for 500 dollars....
#59
Originally posted by dmontzmax
He had it modified. Notice how he had the bumper cut to match as well.
#60
yeah, on the white one, but ngthngs is the same way! He doesn't have the louvers (they can't just be shaved off because the piece is hollow) and doesn't have that slat in the front... ?? Take another look and you'll see what I'm getting at. Why doesn't mine look like that? I like his better .
#61
Originally posted by Matt93SE
Sure.. but how many of you dreamers are actually doing anything about it? (Hint.. that's my shoe in the pic.)
http://www.ee.utulsa.edu/~mblehm/pic...bo/turbo_1.jpg
#62
#64
ok you guys just dont get it...nismo's plight is that the bottom bar of the ww air dam on ng's car is cut out. the physical bumper of his car is not cut jus the bottom crossmember/bar type thing. he wants to know how to cut it out and get it smooth since it is made of hollow fiberglass. ng- i as well as a few others would also like to know how you did it. So,please, enlighten us.
#66
filling holes and such is not that hard. For fiberglass you just cut out the offending part and then lay a few layers of the cloth/resin on the underside of the cut. Let it cure then lay some on the front side. If it's fairly flat after that you can finish up with some bondo designed for fiberglass for minor filling etc..
The only thing hard is following the contours on the airdam. There's one above and below the cutout on the ww airdam. I saw the white car last Sat in person. Needs some work but he said he was gonna finish it later.
To cut out the inner portion of the spoiler, I suppose you can just carefull grind/cut the ledge and then fill with the fiberglass kit. Again, this should be easier as I think there is less contours to deal with.
If you have worked w/ this type of material it's easy. If not, you would either leave the features or hire a pro to do it. It's difficult to get the contours right on each side. It's impossible to see in the pics.
#67
CAn you do me a favor and find out what the offset is on those 19's And if any cutting or shaving was done. Also what is the width of those rims? Bc I believe that only 7 inches will work on our cars without rubbing.
Thanks BIGDOG
Thanks BIGDOG
#68
Thanks BIGDOG
Thanks BIGDOG
#69
Originally posted by Brandon90gxe
duud, what is so hard to think about!? i know what he did and he didnt even tell me. obviosly he bought it and it looked like yours. then he took a saw and cut off those bars. then he cut off the peice in between the bumper lights, then probaly used bondo to smooth it all up, and put a peice of mesh behind! viola! not that hard to see..
A little filler mesh and fiberglass resin and a lot of sanding. That's it!
#72
hey
Thanks BIGDOG
Thanks BIGDOG
ROH @ XRRCD.COM
#77
ngthing....do u still have ur stillen piece?? if so, how much r u wanting for it??
Jeff
jefflinds_24@yahoo.com
shavedmax@alteredatmospherecc.net
Jeff
