Removing Power/Comfort Switch
Old Apr 28, 2002 | 02:16 PM
JoJo428m's Avatar
I am replacing the gauge lights but i can not get the power/comfort switch off. It is a 92SE Auto. I felt around and it seems to lead to a small shaft. I can not take it out w/ a simple flathead as said on Craig B's Page. Help please!!
Old Apr 28, 2002 | 02:23 PM
Matt93SE's Avatar
STFU n00b!
try harder.
Old Apr 28, 2002 | 02:32 PM
JoJo428m's Avatar
Are you suggesting that I try to rip out the dash cover/panel. Cuz if you are, I will
Old Apr 28, 2002 | 03:57 PM
«§»Craig B«§»'s Avatar
this is a job that any 14 year old could do
I think he's trying to say that you actually do just pop it out with a small flathead screwdriver just like the page states
get a small one and work your way under the bottom edge of it, then when you get a little bit up, grab it and pull it all the way out. There will be 2 connectors to it that you can unplug by pushing a small tab on each
good luck
Old Apr 28, 2002 | 04:55 PM
Jaybird180's Avatar
Mostly everthing in the interior of the car snaps in place, retaining itself.
Old Apr 28, 2002 | 05:29 PM
Maximan190's Avatar
Re: Removing Power/Comfort Switch
curiosity, why are you taking the P/C switch out if youre replacing the gauge lights?
Old Apr 28, 2002 | 05:34 PM
Re: Re: Removing Power/Comfort Switch
you have to get that out in order to get the whole center radio/climate control trim piece out in order to get the upper dash gauge surround piece out in order to get the gauge cluster out in order to get to the back of it in order to change the bulbs
duh
Old Apr 28, 2002 | 06:05 PM
Maximan190's Avatar
Re: Re: Re: Removing Power/Comfort Switch
duh
ive only gone as far as taking out the trim piece around the deck/climate control ive never switched my gauge lights i like the stock lights
...besides its easier to get that dash piece out first then the hazard, P/C switch, and lighter
Old Apr 28, 2002 | 06:06 PM
Matt93SE's Avatar
STFU n00b!
duh
Actually, if you pull the trim panel out from the top, then you don't have to remove the P/C switch to get it out. just unplug it from behind.
it's just a little more difficult to get your fingers under the panel to pull it loose.
Old Apr 28, 2002 | 06:24 PM
JoJo428m's Avatar
Ok.....Craig: Well, I'm not 14 am I??
Old Apr 28, 2002 | 06:38 PM
wow, the irony
I had no idea that you were only 13 when I posted that
also, when you're 14, you'll learn about sarcasm too
Matt,Maximan190: yeah, you can take it out without first removing the P/C switch, but I think it makes it easier to pull out that way; either way works
wow, look at all the VEs VE POWER!! (get out of here Jaybird, you're ruining a VE thread)
Old Apr 28, 2002 | 06:46 PM
Maximan190's Avatar
VEs unite
Old Apr 28, 2002 | 11:27 PM
matt1sd's Avatar
Re: Re: Re: Re: Removing Power/Comfort Switch
all you have to do is disconnect the hazards, and you have enough room to get the upper piece w/ the vents out. no need to worry about the p/c switch.
Old Apr 28, 2002 | 11:40 PM
maximum92maxima's Avatar
I just replaced my gauges w/ indiglos and here is what I did
I just layed the entire center piece of to the passenger side with it still attached, I you wanted you could remove it, but like others have said just try a little bit harder, it is a very stubborn piece to remove, but if all your doing is your gauges then just roll it of to the passenger side, if your painting or modifing that center piece, its obvisouly easier to work with out of the car than in.
either way good luck.
Old Apr 29, 2002 | 12:43 AM
Maximajism94se's Avatar
ooh, ooh, i have a ve...can i join the club??? anyhoo, yeah, disconnect from the back or lay it to the side, i just go w/ the others, no uniqueness for me
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
jaydot901
Sep 29, 2015 01:18 PM
lrb6805
Sep 24, 2015 05:03 PM
