bad performance
Old Apr 29, 2002 | 07:22 PM
jaredb03's Avatar
bad performance
can a bad thermostat effect the way your car drives(performace wise)? thanks
Old Apr 29, 2002 | 07:31 PM
DanNY's Avatar
Ad·min·is·tra·tor
yes
Old Apr 29, 2002 | 08:09 PM
jaredb03's Avatar
what would be the symptoms
Old Apr 30, 2002 | 06:56 AM
DanNY's Avatar
Ad·min·is·tra·tor
stuck open - car runs rich a lot - bad MPG.
stuck close - engine overheats
Old Apr 30, 2002 | 07:27 AM
Taegost's Avatar
How would it being stuck open cause it to run rich? Is it because the engine runs cooler (Or, in the case of my car, almost cold on the highway) causing it to try and heat it up?
Old Apr 30, 2002 | 09:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
engine runs too cold. it never reaches operating temp. car is constantly in cold start up mode...runs rich.
Old Apr 30, 2002 | 01:45 PM
jaredb03's Avatar
can it cause your car to lack power when it is warm, or even surge
Old Apr 30, 2002 | 07:14 PM
Bman's Avatar
Is there something else to hint you at the thermostat or are you stabbing in the dark? Yes, it should definitely reduce power if it's running rich but not sure about the "surging"... maybe. Of course if this is the case you should also notice it's taking forever for your car to warm up. Also there should be times when it runs fine, like when the thermostat SHOULD be open.
Either way I think it's time to buy or borrow a repair manual with a troubleshooting guide to help narrow it down - lack of power and surging can be lots of other things too.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
Socalstillen
Sep 26, 2015 12:01 PM
