Injectors and stuff
Old May 2, 2002 | 05:45 AM
male's Avatar
Injectors and stuff
I understand the stock injectors for a vg-30 are 178cc. Is this a fact? If so, and I install larger injectors, say those from a a turbo z31 or TT z32, is in necessary to reprogram the ecu, or will the same pulse width signal coming from the ECU (for the smaller injectors) result in inceased fuel flow on the larger injector?
Old May 2, 2002 | 05:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
you'll need to reprogram the ecu..yes
Old May 2, 2002 | 06:03 AM
male's Avatar
Can I use the stock ECU and injectors from Turbo Z VG-30T?
Old May 2, 2002 | 06:22 AM
DanNY's Avatar
Ad·min·is·tra·tor
actually....it won't work just bolting it on. ecu controls more than injectors.
Old May 2, 2002 | 06:40 AM
male's Avatar
I figured it wouldn't be that easy. Thanks for the input.
---Mike
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
