Irritating problem
Old May 5, 2002 | 03:10 PM
jaredb03's Avatar
Irritating problem
Im having a problem with my car, it surges and it has a loss of power when it gets warm, it is also kind of weak when it is cold too but not as bad. Another thing it is doing is after it has been sitting for a while 1-2 hours, when I start it up it idles weird for a few seconds, and if i put it into drive and take off it almost dies a couple of times, but then after about 10 seconds it is fine. I pulled the codes off the ECU and nothing showed up. Things that i have done is; Changed oil, changed transmission fluid, new throttle position sensor, O2 sensor, cleaned throttle body, put engine treatment in, put fuel injector cleaner in, cleaned the coolant temp sensor, checked the coil plugs, and changed the spark plugs, So do you guys have any ideas what is wrong. If you do please help!! Thanks
Old May 5, 2002 | 10:41 PM
Bryan91SE's Avatar
Lets first start with what kind of car you have? Make? Model? Year?
Old May 5, 2002 | 10:46 PM
maxdout92se's Avatar
Exactly, like i like to ask tha chicks in the club..."What are you working with?" and this is just out of curiousity for other members that might know, is it cool to mix all that ish (engine,fuel,etc treatment) at one time in ya gas tank like that?
Old May 5, 2002 | 11:56 PM
crazy4maxima's Avatar
Year/Make/Model/Trim 92 Maxima SE
Color: pearl white
Mods:
Old May 6, 2002 | 01:54 AM
Bman's Avatar
Howabout your fuel filter? (Not sure about this since you're saying it drives fine sometimes). Drivability gremlins are annoying to troubleshoot. You should buy/borrow a repair manual and prove your engine sensors and "management hardware".
Old May 6, 2002 | 06:56 PM
jaredb03's Avatar
i put a new fuel filter on about 6,000 miles ago, but since then i have put a bottle of fuel injector cleaner in. would that do anything?
Old May 6, 2002 | 07:06 PM
which kind
i remeber that i used lucas gas treatment to clean the injectors.. and that made my car hasitate at low rpms and then i had to keep the engine rev up to keep it from bogging.. it went away after 2-3 tanks of gas.. taht stuff is thick... so becarefull what you put in.. if this happened after you put treatment then that is your answer.. all that gunk that the cleaner takes out clogs the filter.. remember that when you put treatment into the gas tank it sinks and loosens the dirt and crap that was settled on the bottom, now all that is passing through the system starting from the fuel pump throught the filter and on to the engine. all i can say is burn all the gas off waste it... fill up and waste it again.. if you had the car serviced as i did before i did the treatment then that is the culpret. Just drive along on a high way getting you rev up above 2500-3000+rpms.. belive me it happend to me.. i had the tuneup done and i put the treatment.. also got my motor washed... so i relly got the full blunt of bogging slow response, and no pep... drive it off... hope this helps. Any thing you want to add about how tthe car feels.. when does it want to turn off.. Does our rev jump up and down when you come to a full stop.. meaning it will be @ 400rpms then jumpo to 12000 then back down ...?
Old May 6, 2002 | 07:25 PM
jaredb03's Avatar
another thing it does is if i sit with the car on for awhile not giving it gas, just at idle,like in a resturant drive thru, when i take off it wll be fine for about 30-60 sec. and then start surging again like the filter is getting clogged or some thing like that!! is this what happened to you? Also do you think i should run the tank all the way down then put a new filter on?
Old May 6, 2002 | 07:30 PM
nubiannupe's Avatar
OG Maxima.org Member
In all honesty, Jared, it sounds strangly like your MAF sensor. I had a similar problem, 'til someone here in the .org pointed this out to me. Once I replaced that, I've had no problems since... at least not in THAT department.
run the tank down
Keep running the max till atleast two fill it should go away...if anything yo ucan get another filter for like 10 bucks or less... just fill up atleast twice... it shoud be ok
Old May 6, 2002 | 07:37 PM
Maximan190's Avatar
Re: Irritating problem
sounds like typical VE symptoms...yes VEs tend to have a slight loss of power usually when warmed up i notice it too sometimes...how are your VTCs? And yea after i put it into drive from park the idle drops for a second then rebounds. When you shift into drive from park does it hesitate a bit before you feel the car jerk when the gear engages?
Old May 6, 2002 | 08:08 PM
jaredb03's Avatar
i disabled the VTC's, i got the instructions from craigs home page
Old May 6, 2002 | 08:11 PM
did that help
or are you still getting the same response
i am interested in knowing how the whole thing started .. did you add something or mod something... wash water in the engine bay? details
Old May 6, 2002 | 08:14 PM
Bryan91SE's Avatar
Jared, for the second time, what year is your Max? If it's a VE, you need to check the timing, especially if you rewired or if you VTC's are bad. I had the same problem. A manual adjustment of the timing fixed it.
Old May 6, 2002 | 08:16 PM
again i posted its in his profile
Color: pearl white
Mods:
Old May 6, 2002 | 08:18 PM
jaredb03's Avatar
well it started when i had a bad O2 sensor, at first i didnt know what was wrong so i did all that stuff the treatment and other sensors, then i pulled the codes of the ECU, and found out i had a bad O2 sensor and i replaced it. well since putting that O2 sensor on its doing a different kind of surging, diff then before, like something is clogged!! so i don't know what is going on.
Old May 6, 2002 | 08:21 PM
jaredb03's Avatar
so do you think i should put the VTC's back and see if that helps, and if it does ground them again and check the timing? 92 SE!!!
Old May 6, 2002 | 08:22 PM
Bryan91SE's Avatar
Ah, I thought you were talking about yours. I should have noticed the GXE wheels though. I never remember to look at profiles.
Jared, definitely check your timing. The procedure is on Craig's page. It should take about 5 minutes. The crank angle sensor is very easily accessible.
Old May 6, 2002 | 08:26 PM
ok so you got some work done
the next thing would be the vtc which was mentioned, bt i keep coming back to the fuel cleaner... my money is on the fuel filter. Does it run fine on the high way? how much gas you have left when you put the gas treatment and how much you have now... Just try my way.. hey 2 gas tanks and it should be fine if you did a tuneup and changed things in the max.. have you checked your oil and tranny oil levels to make certain you have adequet oil..? my be you can reset the ecu by disconnecting the battery for the night.... you can try that.. you can also try getting a throttle body cleaner and clean the throttle body your self.. really easy.. Ther could be gunk in the holes that inject the gas at the throttle body.... if push comes to shove take it to the nissan dealer.. Try some things see if it helps.. check your spark plugs too. your distributor wires are properly attached to the plugs..
Old May 6, 2002 | 08:30 PM
lol thats ok
the easiest answers to question is search and profiles
Bryan91SE's Avatar
I get a little surging when starting, but that's it. If I were you, I would check the O rings that was discussed on the two solenoids. Make sure you don't have intake leaks.
I guess if you want to narrow the surge down, you can unground them and see if it's the cause. Always look at what was most recently changed. Perhaps that new O2 isn't doing the job?
Old May 6, 2002 | 08:31 PM
jaredb03's Avatar
i have checked the oil levels, and i have cleaned the throttle body, but i don't know how far back i am supposed to clean? how far? and i did reset the ECU. well i think i did. how long are you supposed to leave the battery unpluged? i unpluged it for about 15 minutes
Old May 6, 2002 | 08:34 PM
ok my friend we will get through this
btw if you have aol instant messenger or yahoo or msn messenger get on and lets chat
aol= crazyizzy0619
yahoo and msn = crazyizzy
Old May 6, 2002 | 08:37 PM
Bryan91SE's Avatar
I have some recommendations from the VG Factory Service Manual that may be helpful also:
http://members.csinet.net/tisch/maxima/faq.htm#idling
jaredb03's Avatar
it says your not on msn
Old May 7, 2002 | 06:48 AM
BrodstaR's Avatar
you have a Water damaged ECU!!!!!!
i am from australia (despite what my profile says) and i own a 1993 Maxima, i have just sent my ECU away to be fixed after my car experienced the same problems as yours, don't know what caused the water damage thats for the weekend to find out, rip your ECU out open the bottom cover up and have a look, my guess is that you will see corrosion or rust
sorry to be the bearer of bad news, but you asked
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
