Automatic Shift Knobs ??
Old May 6, 2002 | 05:58 AM
pest2001's Avatar
Automatic Shift ***** ??
has anyone changed their auto shift ***** i really want to change mine so if anyone has a write up about it can u please post them
thanx
william
Old May 6, 2002 | 07:48 AM
dirksmoothe1's Avatar
Re: Automatic Shift ***** ??
thanx
william
I have the Levoc cf shifter, and for the most part... its very simple. there are two screws infront of the shifter on the shifter. Unscrew those. then pull up on the shifter and cut the overdrive button wires. then... dependent on what new shifter you got, I am assuming Levoc, you will need cut the plastic post to size by putting the new shifter on and finding out where it needs to be in order for the top button to work and then mark off the plastic post. slip the new shifters overdrive wiring through the plastic post and then, at this point, solder if you can, or at least try to find a way to connect the new shifters overdrive wiring to the original wiring. now that you have done that, put the plastic post over the wiring and then fit the new shifter over the post as is described in the instructions. There are two screw points in the front of the Levoc, and you will most likely be ablt to us only one, but if this is tight, it's fine. just don't let it get lose.
Okay... this is all assuming that you have taken off the shifter housing that surrounds the shifter in stock form. like where it says PRND12... and all that... and when connecting the new overdrive button... test the actual button before you actually put it all together... you will want to make sure that your overdrive light goes off and on like normal.
there, that is how I did it.
Old May 6, 2002 | 01:18 PM
pest2001's Avatar
http://www.crutchfield.com/cgi-bin/S...0801&display=L this is the one that im lookin to get or this one http://www.crutchfield.com/cgi-bin/S...0715&display=L is there a special way to put these on
Old May 6, 2002 | 05:19 PM
nubiannupe's Avatar
OG Maxima.org Member
Pics aren't showing up, dude.
Old May 6, 2002 | 06:23 PM
thebull's Avatar
well, you can put either of those on, but they dont have an OD switch on them. you can wire it up so that OD is always on, or you can mount a switch somewhere else. i suggest either buying the levoc, razo makes 2 models that are auto and have OD and stillen has one made by levoc for the 300z that would probably work. or just get the aniversary max shift **** for the auto. thats real nice.
Old May 6, 2002 | 06:58 PM
pest2001's Avatar
where can i get it
Old May 6, 2002 | 07:15 PM
crazy4maxima's Avatar
pics pics pics
i would like to see those
Old May 6, 2002 | 07:38 PM
darrick's Avatar
Dallas Nissan Enthusiast
me 3
Old May 7, 2002 | 10:39 AM
ChrisCheezer's Avatar
what about MT ***** on a AT
i have seen ppl do it... but what about the OD switch..? and how do you get the gears to stay were they are if their is no button on the MT shift ****... i would realy like to do that! then get a shifter boot and a MT dash kit lol... i would be the biggest wana-be ever!!!
Old May 7, 2002 | 05:10 PM
pest2001's Avatar
they have one that u push down the whole handle
Old May 7, 2002 | 07:24 PM
OOO is that how it works
can you put any MT shiffter on it and make it do that?... what about the OD.. do MT shiffters have them ?
.. next mod.. lol
Old May 12, 2002 | 07:15 AM
zethus25's Avatar
question
how can i just take out the old automatic shift **** so i could mod it and put it back in? I don't want to have to cut any wires.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
atriuum
Sep 28, 2015 01:19 PM
