Active Speaker Amp ?
Okay first off yes I searched, in fact i search all the time and usually have no reason to post something
I have a '91 Maxima GXE with the "active speaker" (non-bose) speakers.
I've already changed my headunit with a Pioneer DEH-P3300 and did that myself (took old one out and put in wiring harnesses)
now when i bought the deck the installer at the shop told me to make sure i take out the stock amp that powers the rear speakers
stupid me just installed the headunit speakers sounded great for a few days then eventually both rear speakers blew within a week
now i want to replace the rear speakers, but i need to know how do i take out the amp back there and wire the new speakers ???
(yes there is actually an amp back there its shaped like a hockey puck and mouted to the rear deck, i didn't believe it at first from reading posts on the board, but its there only like a 5 watt amp)
I don't want to put new speakers back there and have them go again so any help would be appreciated, thanks in advance
to take out the old amp, just unscrew it. You will have to rewire your speakers though. Here is a link to Craig Braces page:
http://www.geocities.com/bracecraig/maxima/stereo.html
ohh wow thanks, thats great, exactly what i was looking for
was that site updated recently, i've checked it out before but didn't find anything useful
thanks for the quick reply
it says butt connectors, what exactly are those ???
something for connecting two speaker wires together after i snip the wires i need away from the amp ???
Jumpers
What I did was to make four jumper wires and terminated the wires with the appropriate contacts (if you look hard at Pep Boys, you should find electrical contacts that slide into the factory slot).
I unplugged the amp and inserted 4 jumpers. I did this over 2 years ago and it works fine. If I want to sell the car, I simply re-install the stock speakers and plug the stock amp back in.
Butt connectors are just that Butt connectors. Take a look at your local auto parts store and they will show you what they are. You use it to splice two ends of wires together.
Re: Jumpers
Re: Re: Jumpers
Originally posted by awsm66
You need a crimping tool if you use butt connectors unless you use the epensive ones (cant remember the name but they are reusable because the screw instead of crimp)
that's it, I'm taking the site down now
Originally posted by «§»Craig B«§»
yeah, it gets updated every now and then when I find something to add and then when I get around to it
i still love you
Ok now I hope I dont get dissed for this but I tried uninstallin my amp for the non-bose..I followed the directions at Craig B's site. I started off and got my left speaker sounding great...then I did the right speaker..turned on my deck and NOTHING played
.. the only thing that plays is my subs...anybody know what could be up..a fuse maybe??Did I miss a step..HELPP
Are both connectors on your speaker terminals?
Did you wire the correct wires from your head unit?
Did you "forget" to wire the left speaker wires?
Check with an ohmeter (multimeter set to read resistance) that you can see your speakers from the head unit terminals. By "see" I mean make sure you see about 3.5 - 4 ohms. For reference, check your left speaker, since that works to get a baseline...
There is no fuse for your speakers or your audio signals, so it can't be a fuse. Take a deep breath, then attack the problem methodically. It's always something simple when you have problems with speakers not playing.
Alright thanks for the help guys, I just installed my new infinity 6.5 inch speakers in the rear deck
however the wire colours that were supplied to me from craig's site wern't the ones that i used
i pulled my head unit and figured out which wires i used for the left and right rear positive and negaative (4 wires) then found those same colours in the connector from the amp. cut those wires, then looked at which wires came from the speakers, found those same wires in the same connector from the amp, cut those from it, then attached them together and then it worked !!!!!!
kinda sound confusing butt thats how i did it and it works, if you need help PM or e-mail me or something and i will be glad to help out
and craig if you want those colours i used for your site let me know i can get that for you
thanks guys
thanks guys
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
