Help finding 12v power source/wire
Old May 26, 2002 | 03:18 PM
JoJo428m's Avatar
Anyone know of a 12v source I could hook up my rear neons to that are located near/by the rearseat? I appreciate help and a write-up on the process would be nice to
No flames and I tried search
Old May 26, 2002 | 04:18 PM
Maximajism94se's Avatar
if u need some power try stealing some from your fuse panel...u have to take apart the lower part oif the dash and the fuse panel comes out fairly easily...cut a wire and splice the one that needs power into it, u can hook up a switch there 2...hope that helps...
Old May 26, 2002 | 04:57 PM
JoJo428m's Avatar
Yea, I've been messin around down there but I don't know which one
Do you suggest any methods on splicing and reconnecting the wires.....
I've got 4 neons now I've been workin on my interior w/ my steering wheel cover, pedals, gauge light, and a tonna lights and junk.
Old May 26, 2002 | 07:22 PM
not really...try to pick one that has a high fuse rating...like one of the 20 ones...just pull it out, cut it, do thye rest...dont make it harder than it is
Old May 26, 2002 | 07:48 PM
JoJo428m's Avatar
I'll try (hoping I don't accidentally attach the wrong ends)
Old May 26, 2002 | 11:08 PM
mykizism's Avatar
dont just go around messing with the Fuse box, if you dont know what you are doing, cutting factory wire is ghetto
if you need a power source, go get an amp wiring kit or something and get wiring directly from the battery and wire it down the car to where ever you need it.
also you dont cut factory wiring, if you need to tap a line use a wire tap, it pinch's into the wire and wraps it self around it, and you use another wire to plug into it. walmart carrys junk like that look around automotive stores before you start cutting and splicing
Old May 27, 2002 | 08:15 PM
maxdout92se's Avatar
someone correct me if i'm wrong..but if you've replaced ya bose system with aftermarket speakers, you can use the 12v source from there that powers the amps....only thing is, i don't remember where the exactly the source is, but its comin from one of the rear amps!!
Old May 27, 2002 | 09:47 PM
N34JZ's Avatar
Needs non-Maxima Friends
well
the amps are on a remote turn on and if you didnt use an adaptor(and if he asking how to hook up neons then I doubt he did) then there wont be power to the ampd unless you run the remote wire to the power for the stereo and then it may work but for all that trouble just run it off the cig lighter circuit tap in behind the cig lighter, thats got enough power and if you dont use it you might as well/
and you may be the youngest maxima owner but you sure make yourself look like the stupidest sometimes by asking these questions that can be searched if you try meaning try a few combinations.
Old May 27, 2002 | 10:32 PM
crazy4maxima's Avatar
whoa never got pinched.. hmmm.. how about tap into the antenna motor contant power wire in the jack area.. there is a wire that has constant 12v power.. could give that a try...oh by the way arent youa moderator in another forum???
Old May 27, 2002 | 10:51 PM
N34JZ's Avatar
man
some ones up late
btw the way I didnt mean to come off as an as$ but this is a question that can be figured out or easily searched.
Old May 27, 2002 | 10:54 PM
i agree
but hey if we answer the question myu posts goes up, but the bandwidth goes down obtw your
Old May 28, 2002 | 07:39 PM
ThurzNite's Avatar
jsut wondering where you're mounting your neons and how you want them functioning. I was thinking about wiring a neon in my trunk so when I open the trunk, the neon will come on.
Jae
Old May 28, 2002 | 07:43 PM
JoJo428m's Avatar
Yes, I'm a moderator at NissanX.....The Youngest moderator that be also.... My neons are kinda jutted under the cushion of the backseat but point out (ghetto, but I couldn't think of anywhere else)
Thanks for Your answers!
Old May 29, 2002 | 05:49 AM
N34JZ's Avatar
you can
Jae
just wire it up to the light in the trunk that only comes on when you open the trunk, if you want it to work that way.
Old May 30, 2002 | 09:34 AM
ThurzNite's Avatar
i'm such an idiot. thanx for the tip. i'll do that.
Jae
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
doctorpullit
Sep 10, 2015 06:33 PM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
