custom exhaust
Old May 28, 2002 | 10:31 AM
thebull's Avatar
custom exhaust
ok, i know custom exhausts have been talked to death about on here but i was looking through the may issue of scc and thought id bring it up. they completely dismissed all the issues of too big exhaust size. they said that needing backpresure for low end torque is just an old myth. they suggest 2.5 inch piping for 2.6 - 3.0 liter engines. the president from Isuzu Performace wrote back saying that these recommendations are too small and that he has done testing on all different cars to test it. he recommends .25 to .5 bigger. what do you guys think?? why do all the aftermarket companies chose 2.5 for us???
Old May 28, 2002 | 10:44 AM
Matt93SE's Avatar
STFU n00b!
it depends on the RPM range you're looking at also.
a 3L engine that "only" runs to 6500rpm won't need much mroe than a 2.5" exhaust. you'll lose tons of torque down low. there are a bunch of people that have had a complete 3" system made up and they lose tons of low end.. the benefit is that they have more high end.
in our engines, the 2.5" seems to be the best overall size. enough flow for high HP, but also enough constriction for high tq on the bottom end.
Old May 28, 2002 | 12:20 PM
male's Avatar
I second that thought. It all depends on where you want power and aht kind of throttle response . If you don't mind having to stand on it for a min to get the revs up, go big. If you want quick shifting power where you aren't at redline all the time, keep it around 2.5" all the way back. Be advised that this all goes out the window with turbo and SC cars. Both want large diameter to get rid of gases asap, especially turbo. 4" after the turbo is not uncommon on engines equiped with large compressors.
Old May 28, 2002 | 12:35 PM
nismo1989's Avatar
I agree with Matt, unless you are running nitrous in which case upping the diameter a half inch could be benificial at WOT. I would personally stick with 2.5" though. I am going to keep mine 2.5 even with nitrous...
Old May 28, 2002 | 06:13 PM
thebull's Avatar
thanks guys. answered my question
Old May 28, 2002 | 09:33 PM
rift485's Avatar
you guys are just too smart
Old May 29, 2002 | 01:57 AM
mykizism's Avatar
Re: custom exhaust
Originally posted by thebull
ok, why do all the aftermarket companies chose 2.5 for us???
actually greddy use's 60mm exhaust piping which is a lil bit smaller than 2.5 inch
but i`d go with 2.5 inch its about the perfect size for the max
Old May 29, 2002 | 06:42 AM
flyry110's Avatar
i will continue to agree to disagree, but hey, it's all good!
Apr 16, 2020 05:15 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
