E36 light guys help
E36 light guys help
Ive done the conversion and it looks good, but I have some questions:
1) Where should the lights be aimed? or shining on the road .how do i know if they are aimed properly?
2)I think i got them aimed right but i have a small 1/4" gap from the front of the lights to the grille edge and the side to the cornerlight how do fix these and still have them aimed?
3) Craig and/or Brandon, how do i mold in my lights like you have them I know you use a maxima headlight cover but how do you do it?
Any help would be great thaks in advance
im not toally sure but i think only brandon's are "one piece" i think he just removed the cover on the headlights and corner lenses and sealed them up with the clear cover...
craig is using UK corners that are a darker tint so they look one piece.
Originally posted by awsm66
yeah dummy is right just cut and seal.
Originally posted by Damion
Ok but how much do you cat and how do you seal it again?
I must admit that the cut and seal looks awseome but I think for now I wont do it. Theres just something about cutting up 200 dollars worth of lights that doesnt settle with me as long as i can get rid of those gaps i have on the sides ill be happy. The hood gap doesnt bother me at all.
there is not set way to do this you just have to use a little imagination. Look at what needs to be cut mark it and do it.
Originally posted by Brandon90gxe
yea dude, actually what did you do on the bottom side on your lights, because there is only that one tab that sticks out on the covers, so it leaves to gaps on either side. i just cut little peices of plexy and siliconed em in there, i was wonderin what you did..
Damion if you get the covers you dont have to cut the e36 housing for them to look decent...they will look ok if you just put them over the existing housing(top pictures on my site)just not as good as if you cut the lens. That is the only way to get rid of the gap unless you do body work that I know of.
Also back to your first post...I aimed my lights by using the haynes manual for adjustment procedure.
cool thanks for the info now ill have to see if i can get some clear covers and mabye try to make some eyebrows or somthing.
The way i aimed mine was I used WWW.autooptiks.com/aiming.html but i dont know if its right or not
oh by the way awsm66 if i do decide to cut them cam i email you for some rough directions? thanks for your help
NO email Craig and Brandon only...JUST KIDDING...sure no problem I will help if I can. my address is in my profile and on my page
go ahead and email me - dabman15@hotmail.com
ask me anything you can think of, I love junk mail too if you want to go ahead and forward all yours to my address above
thanks
Originally posted by «§»Craig B«§»
no, it's fine
thanks
no, it's fine
thanks
that email is invalid, i just tried emailing it.. wierd..
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
