Missing all the way through the band
Old Dec 3, 2000 | 09:43 AM
gruven's Avatar
I have a 91 Maxima and for the past two weeks it has had a really rough idle. After the car warms up a little, it starts missing bad. Somewhat sporadically, but very often. From idle to the redline. I have replaced the distributor cap, rotor, plugs, and air filter. It smoothed it out, but it's still missing. The car never stalls, but it's just missing. Anyone got any ideas on where to start to figure this one out? Any ideas would be greatly appreciated. Thanks in advance,
Old Dec 3, 2000 | 09:59 AM
DanNY's Avatar
Ad·min·is·tra·tor
this one sounds like a O2 sensor. how old is it?? maybe it's a good time to change it. it's located infront of the cat on the Y-pipe...pointed towards the passenger side of the car.
Dan
Old Dec 3, 2000 | 10:05 AM
block's Avatar
hey dan do you know of any other problems that come along with the o2 sensor being bad besides gas mileage and ruff idle? my car dies every couple of weeks and it has a loss of power sometimes. o2 sensor?
Old Dec 3, 2000 | 11:51 AM
chris92gxe's Avatar
LOss of power is a big effect with a bad 02 sensor. Once changed you will definitely feel the difference if the previos one is bad. The 02 sensor causes many problems other than bad gas milege.
92GXE, touring wing, 18” racing wheels, Port&Polished intake, custom intake, custom yellow interior, racing seats, back seats taken out and replaced with subs and amps, NOS kit, Suspension tech. Lowering springs, custom grille, soon to be custom painted and have the whole engine rebuilt for big shot NOS and custom SC and tranny converted to 5-speed.
Old Dec 3, 2000 | 12:27 PM
DanNY's Avatar
Ad·min·is·tra·tor
does your car run a lot better when it's cold and run poorly when it's hot?
when the engine is cold it doesn't uses the signal from the O2 sensor..so it by passes the signal from the O2 sensor..(open loop i think). so if the O2 is bad it won't matter to the ECU.
when the O2 is heated and the engine is warm it picks up a signal from the O2. if your O2 is lasy or bad your car will run like crap. bad fuel mileage, stalling, black smoke from exhaust, hesitation are all signs of a bad O2. most people will just say "bad MPG = bad O2" which is not the case all the time. best bet is to hook up a ohm meter and measure resistance when the O2 is warm.
good luck.
Dan
Old Dec 3, 2000 | 12:29 PM
DanNY's Avatar
Ad·min·is·tra·tor
c'mon chris..he was asking what else besides the power loss and bad MPG.
Dan
Foo90SE
measure resistance...
Between what 2 wires? White wire and ground? What should the reading be?
Thanks!
Old Dec 3, 2000 | 02:19 PM
AKAICEBERG's Avatar
check the plug wires!!
I had the same problem like 2 months ago. The car would just missfire at a stop, but then after a while it would start missfiring during normal driving and highway speeds. This really freaked me out and pissed me off. I noticed that under the hood there was a blue snapping light coming from one of the plug holes. I think it's time you replaced the plug wires, if you haven't already.
Later,
ICE
Old Dec 3, 2000 | 02:42 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: measure resistance...
after consulting the bible i found a easier way to check it..
have the car running when u disconnect the O2 sensor does the car run worst or no change? if no change then the O2 is shot.
also u can run a diganostic on the ECU.
BTW it states the voltage should be over 1.0 volts when the car is warm.
Dan
Thanks!
Old Dec 3, 2000 | 03:06 PM
Foo90SE
Over 1.0v??? dayum..mine was .245
ill try the disconnect thing
Old Dec 3, 2000 | 03:36 PM
Foo90SE
Oh...i ran a diagnostics on my ECU yesterday(from what i could understand from the sketchy Haynes instructions) and it flashed the 'normal operation' code...but i saw that there were different modes n such, but it gave no instructions on how to get to different modes or anything.
Ill still try to unplug it and see what happens
Old Dec 3, 2000 | 04:08 PM
Foo90SE
Just did the 'disconnect' test...
and the car ran the same. Car was at operating temp. and i pulled the plug and it ran exactly the same
Guess i need an 02
Old Dec 3, 2000 | 09:09 PM
Chris Gregg's Avatar
Get Off My Lawn
Let Us Know....
It seems that everytime someone has a problem, they ask about it and then never get back as to whether what was suggested fixed it! Others who read the threads who have similiar problems don't get any answeres, just a dead end thread. So, let us know for the sake of education!
Old Dec 4, 2000 | 06:45 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Just did the 'disconnect' test...
sounds like it to me. let us know..so i can charge you a small fee..heehee j/k
Dan
Guess i need an 02
Old Dec 4, 2000 | 07:34 AM
gruven's Avatar
Re: Re: Just did the 'disconnect' test...
Guess i need an 02
[/I][/QUOTE]
So how did you 'disconnect' the sensor...Mine has three wires coming out of it without a plug on the sensor...Then I can't seem to follow the wires. Do they plug in somewhere in the engine bay? Or do you yank out the entire sensor from the downpipe or something?
Old Dec 4, 2000 | 08:55 AM
Foo90SE
Theres a connecter...
up on the engine crossmember. Look up by the rear motor mount and you'll see it. Slide the thing off of the crossmember, and u can bring it down and disconnect it.
Old Dec 4, 2000 | 09:11 AM
gruven's Avatar
Re: Re: Re: Just did the 'disconnect' test...
Nevermind that dumb question...Figured it out. But 1) if you disconnect the sensor when the cars off, does it see the connector as a fault and just stay in "warm up" bypassing the O2 sensor forever. Also, 2) If not the O2 sensor, what else could it be (whats the next step)?
Old Dec 4, 2000 | 09:21 AM
Foo90SE
Well i did it both ways....i disconnected it with the car cold and off. I then ran it till it warmed up...and it stayed running the same. Then i cut the car off, plugged in the 02, fired it back up, unplugged the 02 again with it running and warm. It did nothing on my car.
If that makes no difference...then i would check plug wires. When i got my car it was running kinda rough, and when i replaced all that you said you have replaced it still ran like crap...took a voltmeter and measured the resistance of one of my plug wires and it was 100,000 ohms!(acceptable is 25000). So thats a possiblity too. Sucks that these parts are so expensive..most cars an o2 is 18-30 bucks
jmlee44
Oct 2, 2022 02:13 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
conansriver
Sep 16, 2015 12:17 PM
