Strange Timing Problem????
Old Jun 9, 2002 | 06:08 PM
Kraus91SE's Avatar
My car is idling at about 2000 RMP's, and the timing is so far advanced it's about 2 inches past the last mark. I set it to 20deg adv about 2 months ago and sometimes it would run bad and Idle high. Now it does this constantly. I checked to make sure the distibutorto make sure it wasn't loose, and it wasn't. I run 93oct gas all the time and have never had a problem. My thoughts are that a sensor is bad and causing an incorrect reading and the ecu advanced the timing to correct it. Has anyone had the same problen? I'm not sure, but I could use the help.
Old Jun 9, 2002 | 06:22 PM
Kraus91SE's Avatar
I could really some help please.
Old Jun 9, 2002 | 06:28 PM
KLoWnPR109's Avatar
you can change the idle speed if its too high. It tells you how if you have a FSM, Chilton, or Haynes manual.
Old Jun 9, 2002 | 06:29 PM
Terry28's Avatar
Re: Strange Timing Problem????
what is the idle speed??
Old Jun 9, 2002 | 06:59 PM
MaxManMo420's Avatar
2g's is running really high you want it at about 8 or 9!!!
Old Jun 9, 2002 | 09:48 PM
Nismo87SE's Avatar
Try unplugging the TPS, and reving the engine 3 times over 3000rpm. THis should lock in base timing mode. If that doesn't work unplug the IAC and AAC to see if the idle comes down. If it does then U know what the problems are.
Old Jun 10, 2002 | 05:05 PM
Kraus91SE's Avatar
Re: Re: Strange Timing Problem????
My car went back to normal Idle on it's own, But sometimes it starts acting crazy agian
Hondarydr
Dec 30, 2024 06:15 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
kjlouis
Nov 24, 2018 06:09 AM
yat70458
Aug 3, 2015 01:16 PM
