nupe500
Old Jun 10, 2002 | 10:47 AM
male's Avatar
nupe500
Hey man, how did you get the decals off the rear panel of the trunklid? I tried to get at mine with an excato blade. No easy peel-off here. those stickers are well adhered to the surface..any solvent that won't damage the plastic?
--mike
Old Jun 10, 2002 | 04:42 PM
rift485's Avatar
what decals r u talkignabout? i dont have any on my trunk
Old Jun 11, 2002 | 07:06 AM
nupe500's Avatar
Jedi Knight
Re: nupe500
--mike
I didn't check your profile, but since my max is a 91 I just peeled the stickers off. I didn't even need an exacto. But if you have a 92-94 I believe that they are not stickers but actually built into the panel...hope that helps
Old Jun 11, 2002 | 07:38 AM
male's Avatar
Re: Re: nupe500
Mine are stickers too (89 SE), but they are tought o get off. Just wondering if there was a trick to it. Guess I'll have to give it another go.
--Mike
Old Jun 11, 2002 | 07:56 AM
Laly's Avatar
i would try heating them either buying rubbing them with a sponge with hot water or use a hair dryer. i used both to debadge my old jetta. i used dental floss to get it off. since its stickers, i would use a razor blade. i just took off my old tints yesterday and a razor blade worked. make sure you get the adhesive off too. you might want to buy some 3M adhesive remover for that if there is any left on your car. good luck
Laly
Old Jun 11, 2002 | 08:01 AM
N34JZ's Avatar
Needs non-Maxima Friends
Re: Re: nupe500
hey I saw your car at the meet, they did a good job shaving the molding, the new paint looked good too, I was gonna do that do when I get my new paint and kit next month but I was talking with Val (190hpkilla) and he agreed that the molding kinda joins the front to the back and I thought it looked kinda wierd without it, but it also makes the sides look cleaner and more sleek. are you happy with the way it came out? Im not sure if I wanna do it or not,
Old Jun 11, 2002 | 08:35 AM
nupe500's Avatar
Jedi Knight
Re: Re: Re: nupe500
N34JZ
THANKS>.....I DID the moldings myself...they just painted the car....but I love the new look. The car just flows now...no breaks...it took me about a year to do...I was bs-ing...ask chris91se...I had 3 doors done for the longest then finally finsihed the passenger door..and had the car resprayed
Male:
since you have an 89, get a razor then not an exacto...then just scrape the sticker off...you don't need the 3m product for the adhesive...since its not that strong anyways...and has been there for 13 years...it will look weird for a while because that little spot has been clean that look but soon enough it blends in.....I love my shaved moldings....I think I might be the first to actually take mine off and fill them...
Old Jun 11, 2002 | 09:46 AM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: Re: Re: nupe500
I saw someone that had theirs filled but they had the handles shaved too...it was posted on here by flyry110 I believe.
They look real good. I do have a question though. Did you just round them off with the shape of the door or did you put that little crease (on the bumpers and follows up to the molding) all the way across it. I was going to do it but didnt want to fool with trying to put that little crease all the way across because I am not good enough to make it perfectly straight.
Old Jun 11, 2002 | 09:56 AM
N34JZ's Avatar
Re: Re: Re: Re: Re: nupe500
yeah thats what I was wondering about
Old Jun 11, 2002 | 11:19 AM
nupe500's Avatar
Jedi Knight
Guys...not a bad job...what I did was to fill it in with fiberglass...because..the door shell is extremely thin and could be easily warped. I filled it in, then sanded it to the contours of the door. I know of someone who is planning to have theirs shaved, but have metal welded on. There is no crease...just follows the door...hope that helps
stankonia
Oct 22, 2008 03:55 PM
stankonia
Buyer/Seller Feedback
Aug 16, 2007 12:26 PM
Fre$h_TurK
27
Aug 22, 2006 05:38 PM
