Rough Idle
Old Dec 4, 2000 | 12:34 PM
Canuck's Avatar
For about 2 days now, the car has a really rough idle while in drive, and will fluctuate all over the band from 500 rpm to 1100 rpm in just 1 or two seconds. It almost seems like its missing. It goes away above about 2500 rpm, but there is a huge power loss. Any suggestions?
Old Dec 4, 2000 | 12:48 PM
Chris Gregg's Avatar
Get Off My Lawn
Could be a vaccuum leak. There is a canister below the battery, I had a line break there receantly and will have to replace the entire canister, I just sealed the line off for now. Otherwise I would say to check your distributor cap and rotory button, plugs and wires to see if they need replaced.
Old Dec 4, 2000 | 02:06 PM
gruven's Avatar
I had similar problems on a 91 Maxima. Replaced the dist cap, dist rotor, plugs...Smoothed way out, but didn't touch the stumbling problem. Mine was not just at idle but all the way through the power band. Really noticeable though in drive at idle.
The real solution was the O2 sensor. You may want to read the "Missing all the way through the band" thread...It may help.
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
