ABS light issues...
Old Jun 13, 2002 | 11:12 AM
Venumb's Avatar
ABS light issues...
Last night the ABS light started coming on when the brakes were applied. This morning it didn't do it but I decided to do a visual inspection of the brakes anyway. I couldn't find anything mechanically wrong with any of the brakes with the exception of the drivers-side rear brake. That caliper is dragging , just slightly though.I cleaned the rotors and pads with brake parts cleaner and reassembled everything. I managed to get rid of the sqealing I was having from the rear brakes and the light hasn't come back on yet.
Does anyone know some of the common causes of the ABS light activating? I'm more mechanically oriented than electrical, so any info would be greatly appreciated. Thanks in advance!
Old Jun 13, 2002 | 11:15 AM
Terry28's Avatar
Re: ABS light issues...
well sometime like once in two month my Abs light comes on and goes away and i checked the brakes by the dealer and everything and they didn't find anything and there is nothing wrong with my brake. But now it doesn't come on so it migh have been somthing wrong..
Venumb's Avatar
Forgot to mention...
To rule out the obvious...I did check the brake pad thickness,fluid level, and signs of excessive rotor wear or warpage and they were good to go.
Old Jun 13, 2002 | 11:16 AM
Terry28's Avatar
Re: Forgot to mention...
does the Abs light stays on or just fades after awhile??
Old Jun 13, 2002 | 11:20 AM
Jeff92se's Avatar
I'm needing a caw
Run the ABS diagnostics and note the code. Then refer to your Nissan FSM to determine what the code means. Then do the appropiate repair if necessary.
Instructions are here. Read it, know it, love it, then read it again
http://www.bignissans.org.uk/
Old Jun 13, 2002 | 11:38 AM
Venumb's Avatar
Thanks...but I think the problem may have just been solved when my wife pulled up to the house a few minutes ago. The Max was sputtering,ABS light lit,radio shutting self off, dim lights, slow windows, quiet horn. Seems that either the new battery I installed is bad or my alternator is taking a dump on me. I'm beginning to think the dying (now dead) battery is making the ABS system throw a code due to low voltage. I'll update y'all soon. Thanks for the help!
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
maximusrising
Sep 2, 2015 09:55 AM
