What is this connector?
Old Jun 30, 2002 | 02:39 PM
FrankBattle's Avatar
So the car's on jack stands in preparation for changing the front axle. I notice this connector attached to a metal part of the engine right above the center member assembly. It's [sort of] under the rack and pinion boot on the right side of the engine (you right when you are in the car).
The connector has three wires: RED, WHITE and BLACK. One end of the connector is completely cut!! I will connect it back but any idea what this connector is? I'm flipping through the FSM now, so I might eventually come across a description; In the meantime, anyone know what this connector is?
Thanks in advance.
Old Jun 30, 2002 | 03:29 PM
Pervis Anathema's Avatar
Re: What is this connector?
Thanks in advance.
Ten bucks says it is your oxygen sensor. Trace the wire to the other end. If it ends at your exhaust pipe, time to cough up cash for a new one.
Old Jun 30, 2002 | 04:10 PM
Re: Re: What is this connector?
Thankfully, it doesn't. And let me make a slight correction, one end of the connector has RED, BLACK and WHITE wores; the male end has GREEN, BLACK and BLACK (I think).
I will doublecheck the oxygen sensor connector in the FSM, but I have a feeling you owe me $10.00
I accept paypal.
Old Jun 30, 2002 | 04:19 PM
Re: Re: Re: What is this connector?
I accept paypal.
Very well. Shoot me a paypal address... j/k!
Old Jun 30, 2002 | 05:23 PM
Re: Re: Re: Re: What is this connector?
*cough*
Er, ummm.
*exhale*
Okay, so let's, hypothetically, say it does end in the exhaust pipe...would that cause damage to the sensor or anything else? By the looks of it, it's been disconnected for some time [hypothetically].
Oxygen sensor, I assume, controls combustion by sending signals back to the ECU...My gas mileage has been less than optimum for some time; mayhaps this is a root cause, yes?
Hypothetically speaking, I could mail you a picture of a $10 bill.
Old Jun 30, 2002 | 05:41 PM
Re: Re: Re: Re: Re: What is this connector?
I new that was what it was! I saw that same wire combination when I pulled my 02 sensor last week to replace my y-pipe.
Yes, it will drastically affect your gas mileage. The sensor monitors the amount of oxygen in your exhaust. This information is sent to the ECU and is used to adjust the fuel air mixture. A non functioning one will cause a big reduction in gas mileage among other problems. Do a search for oxygen sensor to get better information on this.
I recommend replacing it, especially if you don't know how old it is. Courtesy Nissan in Texas will give a big discount if you mention that you are a member of Maxima.org. www.courtesyparts.com
Good luck.
Old Jul 1, 2002 | 01:38 AM
hadman's Avatar
Hmm..
Why would anyone have cause to cut this wire in the first place? Or do you mean, it was cut by some force of nature?
Old Jul 1, 2002 | 04:35 AM
Re: Hmm..
I'm not sure this is worth answering...
Is a bit different from "I cut one of the connector."
Old Jul 1, 2002 | 10:11 PM
MadMaxBrent's Avatar
I have heard of people cutting the wire when they experience problems with the O2 sensor (instead of buying a new one). Because the car is running rich you don't notice the previous problems of surging and hesitations.
Brent.
Old Jul 1, 2002 | 10:21 PM
No Stuff!!
I'll see what happens when I reconnect it. Thanks.
Old Jul 2, 2002 | 06:44 AM
Maxima_Van_WA's Avatar
BTW get the O2 sensor for the Nissan!! DO NOT get a generic sensor. The earlier cars with the sensor, it was ok to get a generic O2 sensor, but on any of the 90+ cars, get the one for YOUR car.
Old Jul 2, 2002 | 07:11 AM
Brian_TII's Avatar
One "generic" brand that you can get for your car is NTK. It's really NGK, and they make a lot of OEM sensors. You can find these things for sale on www.sparkplugs.com. They are usually a good bit cheaper than OEM, but they are really the same as OEM. (At least for Mazda they are EXACTLY the same as OEM)
Old Jul 2, 2002 | 03:41 PM
eric93SE's Avatar
Yeah definitley replace it. I replaced mine with only 60k on it and I saw a 10% inc. in mpg
AaronL
Nov 15, 2020 11:52 AM
AaronL
Sep 23, 2015 03:34 PM
