Auto Trans. fluid change can it be done on your own?
yeah...the tranny has a drain plug like the oil does. Just pull the plug...3/8" drive...and drain it. Fill w/ new ATF through the dip stick..about 2 quarts. Start car, go through the gears, leave it running, cleck fluid level, add if you need to. Don't forget to put the plug back in.
there is a fliter,but
its a non-serviceable filter it is only changed when they rebuild the tranny .also if you change your own fluid you are only changeing about 20% of the fluid thats in there you need to go jiffy lube or some place that changes all of the fliud by running like 15 qts through it till all the fluids been changed this is the way to do this if the fliud is really dirty.
Re: Auto Trans. fluid change can it be done on your own?
Originally posted by MaxinOut
Is it possible to change the tranny fluid on an automatic if so how cnait be done....
Be well!!!!
Originally posted by DanNY
1/2 inch square..yes he's not joking.
take your 1/2 in rachet in there and go to town.
2 quarts..5 quarts...ook what the dilly/
Alright guys..I've got 46k miles on my automagic and it's about time I changed the tranny fluid. Since I have now idea how to do the disconnect tranny return line thing and risk burning up my tranny - I will drain and fill even if it doesn't replace it all! Now all I need to know is how much dang fluid to pour in there. Too little..you fry your tranny/too much you screw the seals (bah!). Anyhow while i'm on the subject of tranmissions, at 46k it has started to shift alittle hard from 1st to 2nd (gets better as it warms up) and from 2nd to 3rd it doesn't shift quite smooth. It'll let off the gas which you can feel and then it'll shift into 3rd like maybe around 1/3 of a second later...anybody else getting this?
Thanks in advance,
-John
Thanks in advance,
-John
pktaske
May 6, 2016 07:49 AM
ag90fox
Sep 9, 2015 12:22 PM
pktaske
Sep 4, 2015 08:40 AM
