rattlling noise underneath the car
Old Jul 5, 2002 | 10:33 AM
jumpman86's Avatar
when i step on it hard that car makes a rattling noise rite underneath the engine area...if i leave it on neutral , there wouldnt be any noise..i have a 92 gxe auto..anyone have any clue..and also when i get about 3 k rpm..the noise is gone..only in lower rpms..thanks
Old Jul 5, 2002 | 11:46 AM
MaxManMo420's Avatar
probably a loose heat sheild or sumthing
Old Jul 5, 2002 | 12:10 PM
jumpman86's Avatar
yeah i think my mechanic pulled out the heat shield for the cat...so thats gone..cause it was making a rattling noise 2 years ago..and now it happened again..are there anymore heat shield underneath the car..thanks for replying
Old Jul 6, 2002 | 12:40 AM
kingston's Avatar
i had that problem before too. It turned out I had a crack on my stock y-pipe.
Old Jul 6, 2002 | 01:04 PM
johnnyo319's Avatar
I was hearing a rattle from under my car but it turned out to be a loose heat shield. It was rusting off. I had the same symptoms, it would only rattle when i was in Drive or reverse and on the brake at a light or something. The mechanic just ripped if off and problem solved. Just check to see where the noise is coming from exactly.
Old Jul 6, 2002 | 03:37 PM
Freaknificent's Avatar
what are the heat shields for?
are they really important?
whats the cons to taking them off?
Old Jul 6, 2002 | 04:42 PM
Mizeree_X's Avatar
Getting back to his roots
You burn a hole through your floor, I guess. It could also be the metal bracket that supports the cat. Mine was dying, and made alot of rattling noises until my mechanic welded the crap out of it to make it secure again.
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 12, 2015 01:54 AM
