ASP Racing Pulley
Old Jul 8, 2002 | 02:09 PM
D-sta's Avatar
ASP Racing Pulley
Hi everyone. Just wanted to know the guys with the ASP Racing pulley on the VE engine, is it worth it? Does it make a difference? It's listed for $119.95. Let me get some info before purchasing and installation. How hard is to install, looks hard? How much will a shop charge to put in? Thanks
Old Jul 8, 2002 | 05:13 PM
blackandwhite's Avatar
To them I'm like an idol
Re: ASP Racing Pulley
I just put mine on this weekend. Good gains, better for 5speeds. It is not hard.
Take off all 3 drive belts (AC, powersteering/water pump, and alternator).
Remove crank pulley bolt (easier with air tools, but I've done it twice without them)
pull off crank pulley, (may need a gear puller, needed for my VG, but my VE one just slid right off.
put on new pulley (for the VE, I had to beat it on with a 2X4 and rubber hammer)
put on new belts, (the ones listed on the sheet from asp are not exactly right, I'd try a 378K4 for the PS/WP, a 325K4 for the alternator, and a 460K4 (correct) for the AC)
Old Jul 8, 2002 | 06:17 PM
Sith's Avatar
same as above.
excpet go to www.rpmoutlet.com
they are selling it for 99.95
Old Jul 8, 2002 | 07:10 PM
FitzMax's Avatar
How are the gains for the 5-speed VE? It says its a 15% reduiction in weight, but what are we looking at as far as horsepower? Is it worth the money?
Old Jul 8, 2002 | 08:04 PM
poorcollegeboy's Avatar
i have one
the gains are pretty noticable. low and mid range are improved. my 0-60 times dropped too. they are more noticable on 5-speeds though. search this topic. you will find tons of info on them.
Old Jul 8, 2002 | 09:26 PM
Yep
Originally posted by Sith
same as above.
I bought mine from ASP in person. I saw there price sheet. It said the retail was $119, but the wholesale was $79, so it looks like RPM Outlet is still makeing $20 of it.
Old Jul 8, 2002 | 09:52 PM
D-sta's Avatar
Cool, I will order soon it doesn't sound too bad. Can't wait until I have to do my clutch so I can buy a light flywheel for my car. Thanks a lot fellas.
Old Jul 9, 2002 | 12:16 AM
flyry110's Avatar
actually i believe it's a 15% reduction in diameter. i don't think that the weight is calculated. my UDP had to weigh less thanhalf what my stock harmonic balancer weighed. . .
Old Jul 9, 2002 | 12:27 AM
James12345's Avatar
I believe I read somewhere that as a general rule of thumb you make 2 hp for every 1 lb lost off the crank. Just an FYI.
UDP and ECU are about all I'm lacking in the mod category. UDP should be coming soon. The gains are also good for the auto. Aaron says his UDP gave him some more low end grunt and took a chunk of time off his 60'.
Old Jul 9, 2002 | 12:32 AM
Dummy's Avatar
the power gain varies depending on the vehicles current power... and the pullies usually around half the weight of stock.
BkGreen97
Apr 2, 2016 05:47 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
steveyphat
Sep 15, 2015 03:43 PM
