So how much should labor cost for a VE engine swap?
Old Jul 10, 2002 | 02:04 AM
JDwyer2821's Avatar
How much for a shop to do it? I also might ask this guy that has put a engine in a stanza and a 5 series BMW. How much should I offer to pay him? I also was offer $1500+ to have the swap done from a org member.I said forget it because at that charge he's raping me.
Old Jul 10, 2002 | 04:47 AM
Pervis Anathema's Avatar
Re: So how much should labor cost for a VE engine swap?
Why don't you ask how much he is charging and go from there.
Old Jul 10, 2002 | 06:11 AM
Matt93SE's Avatar
STFU n00b!
pull out the yellow pages and see how much the prices are in the area. around here, $1000 is a lot to pay for a swap. in Chicago, $2000 would be a fair price due to labor charge differences.
Old Jul 10, 2002 | 08:32 AM
JDwyer2821's Avatar
labor around here $50 a hour for a good mechanic. How many hours is a swap. Should I try, I have done every modd and mataniance ttoo my max except the tranny or engine
Old Jul 10, 2002 | 09:03 AM
Sudesh's Avatar
I doubt anyone would change per hour to do an engine swap. They take more than a day, thats obvious. It's not like they're gonna be working on your car alone all the time until it's finished, so I they can't chrge per hour, they'll just give you a flat rate.
What you could do to ease the price is remove your old engine yourself, but maybe the'll need to have it in to look at the connections.
not too many ordinary mechanics are capable of swaps..so get someone with exerience.
Old Jul 10, 2002 | 09:18 AM
dmontzsta's Avatar
Ford Only.
A shop near me quoted me $500 to do a auto to 5 speed swap. They were going to take both cars, pull the auto out of one and put it in the 5 speed and vice versa, then I asked how much to swap the motors, harness and ecu he said $500 so a total of $1k I would say look around you should be able to get it done cheap.
Old Jul 10, 2002 | 09:35 AM
Matt93SE's Avatar
STFU n00b!
If you've never pulled a tranny or engine before, I wouldn't recommend learning how on this car. there's a lot of hoses and wires to screw up if you don't know what you're doing- aside form the fact you'll have ~600lb of metal on your head if you drop it.
Old Jul 10, 2002 | 09:45 AM
Jeff92se's Avatar
I'm needing a caw
More like one's foot! AMHIK!
Old Jul 10, 2002 | 09:59 AM
Sudesh's Avatar
bahhh
if the tranny drops on your head or foot a band aid will fix you up good as new. I'm keen to the flintstones band aids.
Old Jul 10, 2002 | 10:04 AM
dmontzsta's Avatar
Ford Only.
Forget the band aid, a real man uses duct tape
Old Jul 10, 2002 | 04:46 PM
davis4005's Avatar
I'm assuming you would have to get a different wiring harness. A tranny swap would be a lot easier than an engine swap, like Matt said there's a ton of wires underneath there.
MAXSE5SPD
Sep 17, 2022 04:00 AM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
FlaMark
25
Aug 28, 2015 10:15 AM
