TX Big Brake kit for 95-03 Maxima
Old Jun 7, 2013 | 06:32 PM
  #41
xWTFxREALLYx's Avatar
so i wouldnt need the caliper brackets for my 98?
Old Jun 7, 2013 | 09:58 PM
  #42
LatinMax's Avatar
No brackets needed.
Old Jun 14, 2013 | 12:18 AM
  #43
559"max"'s Avatar
would like to get in on this. how much shipped to 92337?
Old Jun 14, 2013 | 12:27 AM
  #44
kidgrave's Avatar
Get me a pair while your at it
Old Jun 19, 2013 | 02:47 PM
  #45
olivas's Avatar
Interested how much shipped to 87532??
Old Jun 20, 2013 | 03:04 PM
  #46
LatinMax's Avatar
Sorry for the delay on shipping cost. We had my wife's daughter graduating HS and college orientation that we had to travel away for.
Regardless I was able to get shipping down to a flat rate to $41.95 anywhere in the continental US. So it will be $491.95 Shipped to your door.
Old Jun 20, 2013 | 03:47 PM
  #47
kidgrave's Avatar
This sounds awesome!
Old Jun 22, 2013 | 09:21 AM
  #48
MAXIMA_STYLE's Avatar
So if these use oem 300zx rotors...you said they get machined? machine as in they cut down the rotor to make them a smaller thickness?
Old Jun 22, 2013 | 09:27 AM
  #49
LatinMax's Avatar
No smaller diameter. Thickness stays the same as OEM 300zx rotors.
Old Jun 22, 2013 | 10:43 AM
  #50
So basically i could take the z32 caliper i have here throw on oem 300zx rotors and use them as is without brackets and giant rotors??
Old Jun 22, 2013 | 11:20 AM
  #51
Fauken's Avatar
Yes man, it's no secret, you just have to mill down the 300zx rotor diameter by 3mm.
Edit: also not bad price for the kit Latinmax
Old Jun 22, 2013 | 12:40 PM
  #52
LatinMax's Avatar
Correct. I also directionally cross drilled them.
Thanks, Fauken
Old Jun 22, 2013 | 01:12 PM
  #53
Thanks, Fauken
Ok. Was just wondering. Was contemplating using oem rotors but dont know where to get to get them milled -__-
Old Jul 1, 2013 | 04:42 PM
  #54
rodriguo's Avatar
Long time member, first time buyer.. Are these direct bolt-on to my 2002 Max? If so, how to complete transaction. Thanks
Old Jul 3, 2013 | 07:58 AM
  #55
LatinMax's Avatar
Yes it is a direct bolt on. There are some modds needed to be done to your car for the brakes to fit and clear since they are bigger. The dust cover has to be cut-off and the outer lip on the lower control arm needs to be ground down to clear the back of the rotoe cap since it is thicker and sits back further on the hub than the factory set up. This can all be done with a Dremel or a 4" grinder and some tin snips. The 4" grinder is much quicker on the lower control arm than a Dremel and you can rent it at a local hardware store. I will send pictures and direction on how to install.
I will PM directions for payment options
Old Jul 3, 2013 | 10:41 AM
  #56
kidgrave's Avatar
Is this the process for a 96 maxima as well?
Old Jul 3, 2013 | 11:50 AM
  #57
559"max"'s Avatar
has anyone purchased a kit from you yet?
Old Jul 4, 2013 | 02:07 PM
  #58
LatinMax's Avatar
Yes on all Maxima.
Old Jul 4, 2013 | 02:08 PM
  #59
LatinMax's Avatar
3 on the FB post so far and 2 from our car club. None from here. 5 or 6 that want to as soon as they have money to get it.
Old Jul 4, 2013 | 07:07 PM
  #60
i was told that i needed a bracket and if not i could use one off a 240sx and to use cobra rotors since they are bigger im lost cause on these i dont need one so im confused lol and what is the size on these rotors?
Old Jul 4, 2013 | 07:26 PM
  #61
Crusher103's Avatar
Ive been watching this thread for a while and just wondering what rotors are you using There seems to be a lot of misinformation.
Those seem to the Z32 rotors which they have diameter of 10.9" which is smaller than the OEM 4th gen's 11" but they are thicker rotors. Those are the only rotors that will fit the 4th gens with out the need of a bracket plus the Z32 caliper. Most 16s will actually fit over them(NOT STOCK WHEELS). The caliper is the main upgrade in this situation but the price is fair if lines are included. I didnt want to have to say it.
Old Jul 5, 2013 | 09:33 AM
  #62
LatinMax's Avatar
They are 300zx rotors and calipers. No brackets are required. I have them on my 4th gen (1997). had them on my 5th gen (2001) They are slightly larger in diameter and quite a bit larger in thickness. The bigges gaing is the 4 piston calipers and the cooling of the thicker rotors along with the drilling. Not sure what else I can answer.
But ask ans I shall answer, I have been completely open. The pics show that there is no need for a bracket. It does bolt up. You do need to cut off the dust cover to clear everything and grind the outer edges of the lower control arm. I love the set up and those that have gotten it do to.
Old Feb 20, 2014 | 11:18 AM
  #63
kidgrave's Avatar
Getting these shipped to me within the week I believe. Gonna post up installation pix and a review to go along with it. Should be promising.
Old Feb 21, 2014 | 09:53 PM
  #64
LatinMax's Avatar
Shipped. You should have them by Monday. let me know if you have any questions on the install.
Old Feb 21, 2014 | 10:00 PM
  #65
kidgrave's Avatar
Thank you sir. Will let you know as soon as they are received and installed.
Old Feb 27, 2014 | 10:54 AM
  #66
hitm4n666's Avatar
hmmm i have the calipers already how much for the just rotors if possible??
srry shipped to 02888
Old Feb 27, 2014 | 11:24 AM
  #67
LatinMax's Avatar
Need to get a group together. I may consider doing just the rotors but it needs to be a minimum of 6 pairs. The machine shop is getting too busy to do just one set for me without jacking the price.
Old Feb 27, 2014 | 12:06 PM
  #68
LatinMax's Avatar
I can do just the left & right rotors for $240 shipped in the US via USPS.
Still need a minimum of 5 sets or people to get it done at this price.
Old Feb 27, 2014 | 07:22 PM
  #69
vq4thgen4life's Avatar
I'm definitely interested in Rotors ONLY.
So you have the rotors milled down?
Old Feb 27, 2014 | 09:34 PM
  #70
Maxboy89's Avatar
count me in to on the rotors
Old Feb 27, 2014 | 09:46 PM
  #71
LatinMax's Avatar
Milled down and crossed drilled for a set of left and right, not both in the same direction.
Old Feb 27, 2014 | 10:01 PM
  #72
LatinMax's Avatar
We are half way there. Original post updated. Lets get 3 more so everyone can get there brakes.
Old Apr 10, 2014 | 05:39 AM
  #73
Maxboy89's Avatar
rotors
Any rotors deals Goin on I need them lok
Old Apr 10, 2014 | 10:53 AM
  #74
LatinMax's Avatar
Still need a few more people to get a group deal going. I think we have 3 so far, 4 of you are good to go. Providing the others go through with it. So find one more person so that we have a total of 5 sets and we are good to go.
Old Apr 13, 2014 | 04:51 AM
  #75
Maximeltman's Avatar
can wheel spacers be used if I want to keep the oem 16"s? Interested in rotors as well.
Old Apr 13, 2014 | 08:56 AM
  #76
LatinMax's Avatar
I have read that people have done that to make it work, but do not know it first hand.
Old Apr 13, 2014 | 08:58 AM
  #77
LatinMax's Avatar
I think we are close. If everyone that has said that they are in does come through I think all we need is 1 more person to get the minimum GB done
Old Apr 13, 2014 | 09:25 AM
  #78
LatinMax's Avatar
Original post has been updated and all we need is 1 more person to make the deal come through. You can either order the entire set or just the rotors..
Once we get one more person I will start collecting payments from everyone to get the rotors cut and shipped out. Should not take more than a week from the last payment collected.
Old Apr 13, 2014 | 11:07 AM
  #79
felorojas14's Avatar
Damn!!! On the fence on getting the full kit.
Old Apr 13, 2014 | 11:47 AM
  #80
BIG D MAXX's Avatar
is it all 4 rotors? and what does the kit come with?
