FL FS: 4th Gen Red Grounding Kit
Old Apr 15, 2014 | 08:06 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
This is a SDground Standard kit plus a supplemental alternator ground. This kit has all the benefits of a standard ground kit plus the elimination of alternator whine and even further improved crank up. Here are the benefits of the kit listed:
SDGrounds kit allows your electrical system to work more efficiently by siphoning off power spikes caused by your cars alternator due to irregular power draws and rpm levels during it's operation. This allows for clean precise signals to be sent to the various CPUs and sensors that need them. This has many benefits which include:
Higher gas mileage
Better radio reception
Faster power windows
Brighter interior and exterior lights
Faster and easier start up
Smoother idle
Faster Rev
Faster automatic transmission shifts
Heavy draw electrical accessories like your fan does not cause light dimming or effect your idle in any way.
Longer alternator life
Less voltage spikes means aftermarket LEDs will be far less likely to burn out in your car. (Especially protects on start up)
Aftermarket LEDs will cut all the way off (If you have that problem).
Made 4 Gauge oversized wire with 3M copper terminal ends.
Step by step picture instructions provided in package.
Comes with all mounting equipment needed.
In General your car will feel like new in some ways even better than new in others. (Especially the auto shifts)
I stand by my products with a 30 day no questions asked return policy and a indefinite time frame for build quality.
Looking for $43 shipped. If you need more information you can PM me. My paypal is shinjiduo@msn.com .
Old Apr 16, 2014 | 06:29 AM
maxfever1987's Avatar
Do u have this same kit in black?
Old Apr 16, 2014 | 07:30 PM
Shinjiduo's Avatar
^ Unfortunately, this is the last 4th gen kit I have availible.
Old Apr 16, 2014 | 09:38 PM
sergofast's Avatar
You dont make these for Altimas do you?
Old Apr 16, 2014 | 10:34 PM
Shinjiduo's Avatar
I do make Altima kits from 93" - 12" model years. If you want to order one use my form at: SDgrounds Altima Grounding Kit Order Form
Old Apr 17, 2014 | 06:04 AM
sergofast's Avatar
Thats good stuff. What is the "Big 3"? I couldnt find an explanation of this option on your site.
The instructions for the 3.5 are a maxima...Im guessing this is the same for a 3.5 Altima. Is that correct?
Old Apr 17, 2014 | 01:40 PM
Shinjiduo's Avatar
The instructions are the same for a 3.5 Maxima and a Altima from 07-12. As for the Big 3 upgrade: It adds a supplemental hot lead connection directly from your Alternator + to your battery +. It allows your alternator to far better supply energy to your battery which leads to far superior charging. This is especially beneficial during high power draw moments like when you are at idle with your headlights on, A/C on, radio on and the cooling fans kick in. The big three upgrade is also a must have when you upgrade your alternator, radio or both.
Old Apr 18, 2014 | 08:19 PM
sergofast's Avatar
Nice. I like that you make all these your self. Im guessing it is 4guage wires. Is that correct or do you use a thicker gauge for the big3?
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
doctorpullit
Apr 5, 2017 12:59 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
